2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Will F150 running boards fit a f250
Old 09-26-2017, 05:36 PM
dbraynor's Avatar
dbraynor
dbraynor is offline
Will these FL3Z16A506AA swap for my F-350 stock brackets to bring them closer to the body? When I price these is the price for one or three? Any ideas. If prices I see are for one, $39 and up that is pretty steep. Thanks
Old 09-26-2017, 05:57 PM
Hackenbush's Avatar
Hackenbush
Hackenbush is offline
This is what I used and they come 1 per box, So you need 4 @ what ever price you get.
Old 09-26-2017, 06:33 PM
ctimrun's Avatar
ctimrun
ctimrun is offline
I know this is an older thread but I bought a couple sets of F-150 take off running boards off of craigslist, $40 for one set of the plastic boards from an xl truck and $60 for a set of grey (magnetic) colored steps off of a Lariat.
I have the plastic xl boards on mine right now, haven’t had time to try out the other set. I really like how the boards protect the rocker areas of the truck and also from door dings from idiots swinging their doors out. The door contacts the steps well before hitting the side of the truck.
Looking forward to trying out the little wider Lariat steps with these shorter F-150 step mounts.
Here are the plastic steps......
Old 09-26-2017, 06:36 PM
ctimrun's Avatar
ctimrun
ctimrun is offline
Someone else’s truck with the wider magnetic colored steps.....
Old 09-26-2017, 06:47 PM
ctimrun's Avatar
ctimrun
ctimrun is offline
Interesting that some of Ford’s steps have three mounts/hangers on each side and some of them have two mounts/hangers on each side.
I guess after looking into it a little more some of the F150’s only have two mounts instead of three. Seems like most super duties have three, except the extended super duty steps, which have two on the main step (like the F-150’s), then a third type of support on the rear for the extended portion of the running board.
The plastic steps I currently have on my truck from an F-150 have three.
Old 09-26-2017, 06:55 PM
Hackenbush's Avatar
Hackenbush
I was wondering if the F-250 2WD step brackets are in-between the 150 & the 250 4WD brackets.
Old 09-27-2017, 06:42 AM
dbraynor's Avatar
dbraynor
dbraynor is offline
YEAH that is the look I am looking for! Thanks guys. I need 3 each side. Hackenbush, what did you pay if I may ask? May just go to Craig's list for take off and re-sell after bracket swap if that is more cost effective. Ctimrun I've already had to do PDR as my stock running boards offer zero protection for doors. I know they are not for that, but if I can kill 2 birds....
Old 09-27-2017, 07:05 AM
Hackenbush's Avatar
Hackenbush
They were about 30.00 each (Guess) They do work well for protecting the door dings. But Beware In the winter make sure they stay clean on the top of frozen slush when you open the door. Theres only a couple inches between the bottom of the door and the top of the Step.
Old 09-27-2017, 09:33 AM
dbraynor's Avatar
dbraynor
dbraynor is offline
Benefits of livin' in Fla.
Old 08-13-2018, 08:43 AM
DesertDeezul's Avatar
DesertDeezul
DesertDeezul is offline
So if my '17 SD has running boards with 3 brackets, I have to find F150 boards with 3 brackets as well? Seems like everything im finding on craigslist has 2 brackets per side?
Old 08-13-2018, 08:54 AM
JeepPuller's Avatar
JeepPuller
JeepPuller is offline
I may be able to shed some additional light regarding the 2 vs 3 brackets on the running boards.
My 2017 CC came with the running boards under the doors only; there was not extension beside the bed. These running boards had three (3) brackets.
I found an extended set on CL and swapped them onto my truck. I was surprised to find only two brackets on the main steps and one support for the extension. The steps are surprisingly heavier than the last set, so I was even more baffled by only two (2) brackets.
See this picture comparing them...
Attachment 284828
There are more pics and related discussions here?
Running board swap
Old 08-13-2018, 09:19 AM
broncorif's Avatar
broncorif
broncorif is offline
You only need two brackets per side. I replaced my steps with F150 steps. They are designed for only two brackets. No reason two brackets should not be enough if that’s enough for the F150.
  #28
Old 08-13-2018, 10:44 AM
DesertDeezul
Thanks for the confirmation, I was hoping that was the case. Any idea what year F150 boards work? I've seen people say 2015 and newer?
  #29
Old 08-13-2018, 10:55 AM
broncorif's Avatar
broncorif
I believe it’s 2015 and newer since the body style is the same. I found a set of F150 steps in Magnetic with 4 brackets for $199 shipped on eBay.
  #30
Old 08-19-2018, 07:49 PM
RB-F250's Avatar
RB-F250
RB-F250 is offline
I also did this mod, pretty brilliant. I was able to get 4 brackets off a 2015 F150 on craigslist for $80.
The part number is FL3Z16A506AA, but there is an engineering number printed on the bracket though FL34-16470-AAW.
I have 4 brackets on there now, and it seems pretty stable, but ultimately, I'd like to have 6 again, placing one where the driver and front passenger will constantly be stepping. But it's not a priority, I'm sure without it'll be just fine as well.
Quick Reply: Will F150 running boards fit a f250
