Sponsored by: Real Truck
P0720 Code trying to isolate
Old Feb 21, 2017 | 06:39 PM
acapital's Avatar
acapital
put 75 miles onit this afternoon no issues. Thanks for the help.
Old Feb 24, 2017 | 12:35 PM
acapital's Avatar
acapital
trans temp
See pic. Grabbed a few temps. Looks like I need to check my cooling water temp sensor though.
Old Apr 29, 2017 | 10:37 PM
Apacheco58's Avatar
Apacheco58
Originally Posted by acapital
Update checked the resistance of the OSS from C103. It read about 1.1Kohm. Reconnected C103. This resistance is consistent with the now spare sensor I have. While I had the batteries disconnected I decided to check them as I had a batt low voltage earlier. One of the batteries checked good with the load tester. The other battery dropped off badly when load tested. I had a spare battery, slightly smaller, which was used for something else, it tested good so installed it. Started the truck and proceeded to do everything which caused the fault to appear earlier but this time no fault. Up hill down hill revving from standstill, revving in park....no fault. I remember reading someone having an issue with an alternator causing this to generate the fault. I will drive the truck to town today and see how it goes, and get a new battery, maybe both just to be safe.
Did you ever fix this issue? I'm fighting this same exact issiue to a tee and I'm about to go crazy
Old Apr 30, 2017 | 06:46 PM
acapital's Avatar
acapital
Yes. I replaced my batteries and have not had an issue since.
Gear619
Oct 4, 2017 04:09 PM
Oilfan94
Jul 1, 2017 07:38 AM
wpwilburt791
2004 - 2008 F150
Sep 18, 2014 10:59 PM
our911
Modular V10 (6.8l)
Aug 11, 2009 11:20 PM
