1978 - 1996 Big Bronco
No WindSheild Washer Fluid Pumping
Old Aug 29, 2003 | 12:05 PM
Billy Bronco's Avatar
Billy Bronco
Question No WindSheild Washer Fluid Pumping
Hi,
Have a 93 Bronco and all of a sudden the wind shied washer pump stoped pumping. Wipers go back & forth a few times but, no fluid pumps. Seems it has this 8.25 circut breaker I guess, looks like a relay to me. No change with or with out it. Also light under hood no longer shines, not sure if these are tide together. Any ideas on how to diagnois?
Old Aug 29, 2003 | 12:57 PM
NCO's Avatar
NCO
The same thing happend to me yesterday. I went to autozone and bought a new windshield fluid pump for $15.00. It only takes about 5 minutes to replace it and now it works better than ever.
Old Aug 29, 2003 | 05:53 PM
buckeyebronco's Avatar
buckeyebronco
Yes NCO is prrbably right have somebody push the button for the washer as you listen to the resavour where the fluid goes if you hear nothing then you need a new pump
Old Aug 29, 2003 | 09:17 PM
96bronco58's Avatar
96bronco58
Had intermitent problems with mine working and a new pump was the fix. Its simple to replace.
Old Aug 31, 2003 | 11:07 PM
wild4wd's Avatar
wild4wd
motor may be clogged up
Old Sep 29, 2003 | 01:19 PM
Billy Bronco
Seems all it needed was the connection to be sprayed with WW-40, works fine now.
