:-huh Darn it....!!!
on
Example: A shop that works on equipment trucks, forklifts etc. should be able to set that up in a small hydraulic press quite easily and get it right off. Therefore I think that any good automotive or truck shop should have enough adaptors and accessories for their hydraulic press to figure that out in a few minutes and get it off. If they can't take it to a better equipped or older shop with more experience.
[EDIT to add] Don't let anyone try to pull it off by the edges with a gear puller as it will bend and ruin it.
If it does get ruined in getting it off- no big deal: MOST of the older Ford trucks in the wrecking yards use the same power steering pumps and pulleys. I needed a power steering MOUNTING BRACKET so I used my power steering pulley remover kit/installer to remove the pulley right in the wrecking yard. You can BORROW a remover kit from the parts stores as a LOANER, place deposit and you get it back when you return the tool. Unethical? It's kinda OK, if you normally buy parts at that store.
mrfox0246
08-02-2012 04:33 PM
velella
09-01-2004 12:31 AM
teederj2002
02-23-2004 01:55 AM
