approximate price please-fuel tank, pump etc
Old 02-17-2017, 08:06 AM
RJL1's Avatar
RJL1
RJL1 is offline
Can someone give me a guess on what parts I need to replace my leaking front fuel tank. I'm guessing I'm needing a front fuel tank, tank straps, fuel pump. What else do I need? What am I looking at in prices for parts? And lastly what would you estimate a shop charge to install all? I'm thinking I'm gonna install it myself, but if it's not a labor intensive job I may opt to have someone install it. I'm an excessive planner and expect to do this job in April or May.
Thank you
Bob
Old 02-17-2017, 10:32 AM
BeholdenZippy's Avatar
BeholdenZippy
BeholdenZippy is offline
Fuel filter, lock ring for the fuel pump(most tanks come with one), quick disconnect fuel line tool. Depending where you get parts, I would plan 100 for the tank, 150 for the fuel pump, 40 for the straps, 5 for the lock ring, 15 for the fuel line tool, 10 for the fuel filter. Probably cost 300 or so for labor depending on labor rates in your area. I would stay far away from airtex fuel pumps. I would recommend you do the work yourself if you can.
Old 02-17-2017, 12:34 PM
RJL1's Avatar
RJL1
RJL1 is offline
Great! Thank you for the info. I'm gonna give it a shot in a month or so. I'm retired and only work a few days a week so I plan on picking away at it. Gonna install new Bilsteins too.
Old 02-17-2017, 12:52 PM
BeholdenZippy
I don't know where you usually shop, but advance auto has 20 percent off if you order online. They can deliver right to your house. I did check the prices on a few things and they were right around what first guessed it at. I haven't put many miles on it, but my Delphi fuel pump is still working good and is quieter than the one I took out.
Old 02-17-2017, 01:05 PM
RJL1's Avatar
RJL1
RJL1 is offline
Thank you. Again I appreciate you taking a minute and helping out. Thats where I usually get my parts anyway. Great tip.
Old 02-17-2017, 01:34 PM
BeholdenZippy
No problem. Good luck on your repair.
Old 02-17-2017, 02:08 PM
Fastback460's Avatar
Fastback460
Fastback460 is offline
I did mine a few years a ago and bought one from Autozone for around $300. It came with the tank, straps, lock ring, and the fuel pump already installed in the tank.
Old 02-17-2017, 02:20 PM
BeholdenZippy
Any issues with the spectra fuel pump?
Old 02-18-2017, 06:50 AM
RJL1's Avatar
RJL1
RJL1 is offline
Hmm.. Sounds like what I'm looking for. Thanks.
Old 02-18-2017, 07:51 AM
Fastback460
It's been about four years and I haven't any problems so far. *knocks on wood*
Old 02-18-2017, 09:24 AM
BeholdenZippy
Glad you are having good luck with it. I thought about getting the preassembled tank when I did my rear tank, but I heard mixed things about spectra fuel pumps. I ended up just buying a tank so I could put a Delphi pump in it.
Old 02-18-2017, 10:07 AM
MR KROGOTH's Avatar
MR KROGOTH
MR KROGOTH is offline
Old 02-18-2017, 10:13 AM
phoskins's Avatar
phoskins
phoskins is offline
Since you have some time before you plan to do this, shop around online. I bought a Spectra tank at my local NAPA distribution center store for around $100, then found the same one at Amazon.com for less than $60. Delphi pumps are supposed to be good, so far mine's been good, but I don't have many miles on it yet.
Old 02-18-2017, 12:32 PM
TheGreat460's Avatar
TheGreat460
TheGreat460 is offline
I didn't put in a new tank since mine was just fine. I paid $6 for a cheap fuel line disconnect tool and $130 for a precision fuel pump that has been great for the past 1500 miles and is still going good.
Old 02-18-2017, 03:26 PM
RJL1's Avatar
RJL1
RJL1 is offline
All great info here and much appreciated. I'm a huge planner and researcher before I take on a task I haven't done before. It's even aggravating to me. I've been on both advance auto and autozone sites. I like the all in one product, tank, pump, straps and lock ring. I have a fuel line disconnect tool(s)that i purchased to change out the fuel filter on my motor home with an F-53 chasis.
Thanks again, I really like this site. Very helpful.
Bob
Quick Reply: approximate price please-fuel tank, pump etc
