Brake pad recommendations needed.
Old Feb 14, 2017 | 07:30 AM
Tnriverside's Avatar
Tnriverside
It's finally time for new brakes. My 2009 F150 SC 5.4 needs new front brake pads. With 109,000 miles on it I can't complain but I do hope to improve. While pulling my travel trailer I have had a few white knuckle moments. This happens at the end of a quick stop when the brakes seem to fad. So I'm looking for recommendations on replacement brake pads. I would like to keep the stock rotors. I have used EBC pads on my Harley's and liked them but not sure they are my best bet for the truck.
Old Feb 14, 2017 | 10:11 AM
meborder's Avatar
meborder
I've been using Wearever Platinum's from Advance Auto for a number of years now.
they are ceramic and seem to stop better the harder you stop. I've never had them fade, but I've never pushed my luck with them either.
so far I've used them on my explorer and expedition and they have been really great when towing. No noticeable dust either. Plus they come with all the pad hardware, so they are cheaper than buying a less expensive pad and then buying the clips/retainers.
I'm happy enough with the performance of these pads that I will be using them on everything until they are no longer available.
my $0.02
Old Feb 14, 2017 | 11:10 AM
ubereal2's Avatar
ubereal2
I've used Wagner Thermo Quiet brake pads for years. Depends on application, but you can get them in semi metalic, or ceramic. I mostly use the metalic pads, and I get at least 75K out of them. But I do little towing, and I'm not hard on brakes. And vary little brake dust. Orielly's stocks these, also brake rotors, and drums, as well as other brake parts.
Unk Bob
Old Feb 14, 2017 | 12:33 PM
WXboy's Avatar
WXboy
I use Motorcraft pads only, and get them from rockauto.com here lately. I've tried ceramic pads but they don't bite as hard, and I've tried semi-metallics but they dust like h***. So the OE pads seem to be the best I can find.
Old Feb 14, 2017 | 06:21 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
At 109K, I can't seem to find a good reason to switch pads.
Old Feb 14, 2017 | 07:04 PM
Tnriverside
I can't complain about the mileage but the fading while pulling the travel trailer has me looking.
Thanks for all the comments.
Old Feb 15, 2017 | 05:24 AM
tseekins's Avatar
tseekins
Could the fade be somewhat caused by your rotors?
Old Feb 15, 2017 | 10:47 AM
King-bRanch's Avatar
King-bRanch
To the OP, I've had several different Brands of "upgraded brakes" over the years & IMO especially for the price, POWERSTOP has nailed it. I have been pulling a 2016 Jayco TT (appx 5200 lbs) with absolute ease. In no way is my F150 as capable or pull anywhere as efficiently as my F250 Powerstroke pulled our 31' 5th-Wheel, but that would be comparing apples-oranges. The point is the F150 gets the current TT moving ok, but it gets it stopped very good now.
Check out my Link here....
https://www.ford-trucks.com/forums/1...l#post16559929
Old Feb 15, 2017 | 11:35 AM
SGR F150's Avatar
SGR F150
I agree here...POWERSTOP kit. I upgraded to 35" tires and the brakes couldn't handle it. OEM pad cracked and tore up my rotor in no time. Upgraded rotors and got the carbon fiber/ceramic pads. Brakes grab so hard now (when you stomp them) that it almost overrides the "anti-lock" (tires will leave rubber on the road, but don't lock down.
Old Feb 15, 2017 | 11:58 AM
David W Jones's Avatar
David W Jones
Wagner Thermo Quiet. Rock Auto.
Old Feb 15, 2017 | 04:07 PM
Turbo Dog's Avatar
Turbo Dog
I chucked my pads and rotors at 20K miles, installed Power Stop drilled and slotted rotors with Hawk ceramic pads. I'd estimate that I gained about 20% stopping power.
jeffreyclay
Apr 13, 2019 05:01 AM
Rusty_Old_F250
Jul 29, 2012 08:14 PM
cmdevildog16
Dec 20, 2011 07:49 AM
Hybris
1997 - 2003 F150
Nov 3, 2010 10:09 AM
Mas360
Jun 14, 2010 03:29 PM
