transmission problem ?
Old Aug 29, 2003 | 02:14 AM
whats wrong's Avatar
whats wrong
i have a 1990 2.9l ranger , dont know what trans , but after my truck warms up the transmission has a hard time shifting and when it does it shifts real hard and the rpms go real high before it will shift , when the motor and transmission is cold everyting is fine , it works great , transmission fluid and filter was changed 2 months ago
Old Aug 29, 2003 | 09:20 AM
Ken00's Avatar
Ken00
Welcome to FTE!!!
I'm not into trannies but I'm sure someone will have some ideas or you could try posting at our tranny forum.
Old Aug 29, 2003 | 04:41 PM
rclarke's Avatar
rclarke
1990 ranger should have an a4ld transmission. You might pull the hose off the vacumn modulator. If fluid runs out change the modulator.
Old Aug 30, 2003 | 10:55 PM
jbone672's Avatar
jbone672
if the modulator thing doesnt work, try the throttle position sensor. i have a t-bird that was doing almost the same thing and i changed it on a hunch and it worked, its easy to do. good luck!
Old Sep 5, 2003 | 04:49 PM
trista's Avatar
trista
My 95 ford ranger does the same thing also. At first I took it to a transmission shop and they told me that I didn't have second gear. ha ha If I didn't have second gear why would it shift into second gear why would it drive when you put it in second gear, then I went and got a more professional opinion, they said it was also the modultor
Old Sep 16, 2003 | 12:45 AM
big blue ranger's Avatar
big blue ranger
I have a '91 4x4 with a A4LD tranny which is what you have im pretty sure. I have rebuilt this thing 5 times already. I can tell you from experience that most likley your having problems with your governor, probably due to debri inside your tranny clogging it up.
Its not a simple fix, your going to have to pull your tranny and open it up, so you may as well rebuild it while your there. I love my ranger but ford put in the worst tranny possible.
