Sponsored by: Real Truck
ART Rotors....HELP!
Old Aug 29, 2003 | 01:31 AM
FlyinFord's Avatar
FlyinFord
ART Rotors....HELP!
i just recived my new ART rotors for my truck and which one is left, and which one is right....there is no R or L stamped on them....which one is which??
Thanks for the help!
FLYINFORD
Old Aug 29, 2003 | 03:10 AM
HeavyAssault's Avatar
HeavyAssault
ART Rotors....HELP!
Never knew rotors were one-sided. It shouldn't matter which goes where...
Old Aug 29, 2003 | 05:24 AM
jaxf250's Avatar
jaxf250
ART Rotors....HELP!
Heavy - these are slotted rotors with an angle slot, so in this case it does make a difference.
The driver's side rotors have their slots going this "/" way when viewed on the truck, and the passenger side go this "\" way.
HTH.
Edit: oh yeah, the front/rear are different too! If I recall correctly, the heavier (thicker) rotors went up front. I just matched 'em up to what I took off the truck, since they are not labeled in any way from ART x/c for markings on the outside of the boxes.
Old Aug 29, 2003 | 06:24 AM
HeavyAssault
ART Rotors....HELP!
You are correct, I forgot ART rotors were slotted.
Old Aug 29, 2003 | 07:06 AM
JTATMAN's Avatar
JTATMAN
ART Rotors....HELP!
THE BOX THEY CAME IN SHOULD HAVE A LEFT OR RIGHT PRINTED ON THE LABEL.THE ROTORS DO NOT.
I KNOW HOW YOU FEEL,I TOOK THEM OUT OF THE DA$M BOX & I HAD TO REMEMBER WHICH ONE CAME OUT OF THE BOX MARKED LEFT & WHICH ONE CAME OUT OF THE BOX MARKED RIGHT.
THIS IS THE ONLY DRAW BACK TO THE ART ROTORS.YOU WOULD THINK STHAT OMEONE COULD SMACK THEM WITH A HAMMER & PUNCH (L OR R).
SEE YA,
Old Aug 29, 2003 | 11:22 AM
FlyinFord's Avatar
FlyinFord
ART Rotors....HELP!
Thanks for the replies...just one question for jaxf250. You say that on the passenger side the slot should be "\" when viewed from the side of the truck, but in the pictures in the link, you can see the tail pipe (indicating pass side) and the slots are facing "/".
Which way is correct?
FLYINFORD
Old Aug 29, 2003 | 11:52 AM
jaxf250's Avatar
jaxf250
ART Rotors....HELP!
From about the noon or 1 o'clock position (if you were looking at a clock) on the passenger side, when viewing straight on, they should be going like "\" this.
