What does the far left button above the sync screen do? The other 3 are traction control, hazards, and hill descent. I think it may be exhaust brake and it seems to have 2 different settings but I can't seem to find anything about it in the manual and when I push it nothing obvious seems to happen.
Checked the manual again. Found the answers I was looking for in the brake section. It is indeed engine brake and if anyone is wondering the first button press enables manual control mode and the second press enables automatic mode and then third press turns the system off again.
And that engine/exhaust brake really works! I was coming down a steep set of switchbacks and I turned on the engine/exhaust brake button. It wasn't quite like going from 4Hi to 4Lo but I most certainly could tell that it was working.
Hmmm, I was under the impression it only worked in tow/trailer mode. Guess not! Thanks, I learned something new today!
I'm pretty sure I was NOT in tow/haul. I was in manual mode and had the transmission in 2nd gear and then hit the exhaust/engine brake button and bam! the truck slowed down a lot faster.
You may be correct!, I might of rec'd this info from the new Denali I test drove as well. I'm sure others here with the truck in hand can confirm.
I am curious how well it works as well. On my current Ram dually, the engine brake works by itself, BUT if you put tow/haul on, it works much better as the truck automatically gears down on decent.
Not sure how well it works in Tow/Haul mode, since I haven't towed anything yet. I use it often, figure might as well let the engine slow the truck some maybe save some brake pad in the process. IMHO similar to the way I use the manual transmission to slow my car.
That's entirely what I do in my Dodge. It's become habit for me now. Every time I jump in a automatically turn on engine brake and tow/haul. (I live in hilly county) it sVes on your brakes big time.
I don't know if it resets on restart, but I suspect that it does. There is an icon on the dashboard below the tachometer as I recall.
Thank you, Icon solved!
I'd go and try the exhaust brake, cycle the truck to confirm it stays on (or resets to off), but I can't!.... yet ...my F350 is on order and not due in until 2/28-3/6
I'd rather put brakes in than a transmission any day! I'm only going to use this feature for safety, not to save a $40 set of pads.
Well with a combined milage of about 350,000 KM's I have yet to have an issue. I routinely pull a 43' toyhauler in steep grades with zero issue as well. I've yet to hear of a premature failure due to using the engine brake that was engineered and designed for the truck.
Do you run it in automatic or manual mode. Also, whats the difference between the two modes.
