Multiple electrical issues. Are they related?
Old Feb 12, 2017 | 08:46 PM
Danger Ranger FX4's Avatar
Danger Ranger FX4
My 2006 F150 was purchased by me in early 2009 with about 28,000 miles on it. It's an XLT crew cab 4X4 with the 5.4. Stock except for a leveling kit and an aftermarket head unit. It currently has about 59,000 miles and has been babied since I purchased it. About 3 years ago I started noting some issues:
A. Oil pressure dummy gauge is all over the place. Some times it will show no oil pressure. Other times it is all the way to the highest mark. Other times the needle has gone 180 degrees past where normal is and is actualy pointing straight down towards the floor.
B. Recently my alternator dummy gauge has started doing the same thing as my oil pressure gauge.
C. The backlight behind my odometer works intermittently, but mostly not at all.
D. My dome light will flicker when first turned on. It doesn't matter which door is opened or if the override switch it turned on. It takes several seconds to come on and will flicker like there is a poor connection somewhere, but stays on once its on.
E. Blower fan will occasionally stop blowing. Once the climate control switch is turned to off, then back to on it resumes working. This doesn't happen often, but does occasionally.
Fortunately, the truck has not left me stranded and I want to keep it that way. We are getting ready to sale my wife's Toyota and this will become her daily driver. I want to take care of any issues before she starts driving it. Are these all separate issues or is there one common issue which could be causing them all? Thanks in advance.
Old Feb 13, 2017 | 06:38 AM
bbender85's Avatar
bbender85
everything you listed runs through the instrument cluster. i'd take a look at the connections.. fortunately these trucks aren't too hard to get the dash parts off to do so. i can have mine apart in under 5 minutes now.
piperpilot
1997 - 2003 F150
13
May 26, 2015 02:07 PM
avking2508
Mar 10, 2014 02:16 PM
dragford
Jul 6, 2009 06:33 PM
SilverSport
Feb 12, 2007 10:04 PM
buckman9
Oct 14, 2003 02:34 PM
