timing
Old Aug 29, 2003 | 12:10 AM
speedy252f's Avatar
speedy252f
Lightbulb timing
i have a 1984 Ford E-150 With a straight 6. How do i get the timing perfect?
Old Aug 29, 2003 | 12:35 AM
Franklin2's Avatar
Franklin2
timing
Do you have a vacuum line going to your distributor? This will determine if your timing is electronically controlled, or the old fashion mechanical controlled.
Old Sep 5, 2003 | 05:59 PM
f100guy's Avatar
f100guy
timing
if you are replacing the timing chain and it is like a v8 then you turn the engine to tdc on #1 cylinder make sure your rotor in the cap is pointed to #1. it is fairly easy
