alternator output voltage
Old Feb 11, 2017 | 03:52 PM
spooktn's Avatar
spooktn
My 99 Ranger 3.0 is only being driven once a week if that,,I had to charge the battery yesterday,,i do not think it is being driven enough to keep the battery charged. my guage is about half way( in the middle when truck is being driven) and not sure what the exact voltage is.If I use my volt meter at the battery when truck is running what should the voltage output be with full charge on the battery???? Should I turn on headlights and see if that voltage changes ??? I just guessing it should be about 13 volts with lights off and about 14.5 with lights on,,,but I am just guessing at these volts. So any help here would be great just to make sure my alternator is working right.
Old Feb 11, 2017 | 05:39 PM
Conanski's Avatar
Conanski
With a multimeter the battery should measure about 12.5v with the engine off, and with the engine running you should see 13.5-14.5v depending how many electrical loads are on.
Old Feb 11, 2017 | 09:41 PM
spooktn's Avatar
spooktn
Thanks that is exactly what i needed to know,,,will check it with my meter first thing tomorrow
Old Feb 12, 2017 | 02:56 PM
Ranger88Den's Avatar
Ranger88Den
You might want to use a solar charger, just make sure, if using the cigar lighter plug, it's hot with the key off.
briangregory
Feb 2, 2018 10:09 AM
NotEnoughTrucks2014
Apr 4, 2017 06:48 PM
TobaccoBarn460
Sep 30, 2016 02:41 PM
2001SuperCrew4x4
1997 - 2003 F150
Aug 3, 2011 12:58 PM
bsmith8
Electrical Systems/Wiring
Jan 5, 2004 05:27 PM
