20" wheels combo fit?
Old Feb 10, 2017 | 06:26 PM
Misky6.0's Avatar
Misky6.0
Make darn sure those wheels are HUBcentric, lots of aftermarket wheels are LUGcentric and you'll just throw money away.
Old Feb 10, 2017 | 06:42 PM
Irish19614x4's Avatar
Irish19614x4
First off yea I'm not buying anything lug centric so I'll double check. That part I know of when running spacers on my DRW while back making sure to buy the spacers that were hub centric.
As for 2008 F250/350 why would those be specific to need spacers? Now would I need spacers on all 4 or just in front? Damn though if it's gonna cost me $800 in spacers then maybe I won't do it and just keep looking for a set that will bolt up without spacers. If that's the case what ones should I be looking for? I like the 18" or 20" setup don't want to be in a current 16" or 17".
Old Feb 10, 2017 | 06:52 PM
Misky6.0's Avatar
Misky6.0
The '05+ front AND rear axles are several inches LONGER, thus the wheels are set up to bring the tires in to the correct spot.
Putting those wheels on the SHORTER axles causes the tires to be a couple inches inside the wheel wells. On leaf spring front 4x4 the tires will hit the leafs much more.
Putting spacers only on the front, looks silly, with the rears "sucked in", in my opinion, chevy 4x4 have that look, the front tires have a wider track than the rears.
Old Feb 10, 2017 | 07:10 PM
Irish19614x4
Okay thanks for that explanation damn it didn't want to hear that lol. Well time to think of it's worth it or not.
Here is photo of his truck with wheels and tires before he took them off.
Old Feb 10, 2017 | 07:18 PM
Irish19614x4
Originally Posted by PSUhoss
if they are from a 2008 f250 or 350, you will need spacers to run them on your excursion. If you want good spacers, they will cost you almost as much as you are going to have in the wheels and tires.
these are the spacers that I am running:
www.wheeladapter.com
Looking at website for spacers the ones I'll need is making 8x170 convert to 8x200 right? At $570 a pair? Since this is coming from a 2008.
Old Feb 11, 2017 | 08:19 PM
seijirou's Avatar
seijirou
You don't need to convert to 8x200, that's for a dually wheel.
Hit this, choose excursion, then scroll down to 2" thick. $110 each.
http://www.motorsport-tech.com/speci...d_s?Next=16-30
Old Feb 12, 2017 | 12:00 AM
Irish19614x4
Wheel Adapters, Wheel Spacers, Hub Rings for your car! | Motorsport Tech
$110 BUCKS a piece isn't bad
roadpilot
Aug 8, 2018 07:26 AM
Skidooer16
Nov 2, 2016 09:27 PM
TripleCorpseHammerblow
Aftermarket Products
May 31, 2007 01:56 PM
Johnnyboy04
2004 - 2008 F150
Nov 1, 2004 07:47 PM
Screamin T/A
Feb 20, 2003 09:09 AM
