Truck Steering Randomly Pulling
Old Feb 8, 2017 | 03:07 PM
F-ReV's Avatar
F-ReV
Ok so I just took my truck out for a drive to the auto store and I left the parking lot turning right onto the road. Once I got on the road the truck kept wanting to pull to the right the entire time I was driving. I pulled over into another parking lot and when I turned left into the lot it then started to pull the wheel to the left. So I parked the truck to check if I could see anything obvious causing an issue. There was no obvious obstructions so I hopped back in the truck and turned the wheel left to right, it felt like something was holding it up when I did this and it felt as if it all of a sudden let loose. So I decided to just baby it home and when I got back on the road the truck felt normal again with no pull. Steering pump was a low so I filled that up, and I guess next I should just check out the suspension. I plan on replacing the front suspension but wanted to wait until summer Any ideas what the problem may be are greatly appreciated
Old Feb 8, 2017 | 03:28 PM
White 97 xlt's Avatar
White 97 xlt
Is it 4X4? If so check for frozen u-joints in front axle...
More details on the truck would help...
Old Feb 8, 2017 | 03:33 PM
F-ReV's Avatar
F-ReV
It's a 95 F150 4x4 I6 5spd, and thanks I'll be sure to check the ujoints I saw someone mention that in a post I read
Old Feb 8, 2017 | 04:00 PM
88XLTLariat's Avatar
88XLTLariat
Also, check your steering column intermediate shaft and the lower rag joint for any play.
Old Feb 12, 2017 | 02:38 AM
_Trekker's Avatar
_Trekker
Your steering shaft, ball-joints, tie-rod ends, track bar, and drag link ends would be what I would look at considering it changes which way it pulls. Track bar would usually make it track sideways also. If you don't find anything wrong sometimes cross rotating your front tires (swapping side to side) will fix a pull without an alignment. Worst case scenario in my mind would be that your steering gear may have some play in it whether it be where the pitman arm connects to it (nuts do come loose especially on lifted trucks) or internally it is starting fail.
Old Feb 12, 2017 | 08:25 AM
My4Fordtrucks's Avatar
My4Fordtrucks
^ That was my first thought since it wanted to stick in whatever direction you turned.
Old May 19, 2017 | 04:53 PM
cranegrad's Avatar
cranegrad
My 95 F250 is doing the same. If it sits for a week or so the steering pulls left or right. Mostly right. What I don't get is why it resovles itself the more I drive it. The steering isn"t tight by any means but after a few days driving it feels normal again.
Old May 19, 2017 | 05:15 PM
Conanski's Avatar
Conanski
Dried out U-joints is the likely cause IMO, if they are greasable try to force some lube in there, if not they are original and well past their due date... time for replacements.
Old May 26, 2017 | 08:13 AM
cranegrad's Avatar
cranegrad
OK, I'm pretty much resigned to the fact that I'm going to change the axle ujoints and ball joints both sides. Should I do the outer tie rods while I'm in there? This will break my budget anyway because I'm not doing the work myself...
Butch(OH)
Jul 6, 2013 11:13 PM
jiveturkey692000
Mar 14, 2013 06:04 PM
highteckredneck
Feb 6, 2013 09:51 AM
senix
Oct 26, 2009 07:14 PM
katbird704
Aug 26, 2007 06:24 PM
