electrical problems.help!!!!!
Old Feb 8, 2017 | 11:14 AM
jakesterrocks's Avatar
jakesterrocks
i have a 2000 ex,6.8 4x4.every now and then the dome light stays on.theres also a problem where theres a buzzing sound coming under dash while driving and makes the dome light flicker.these are seprate problems.lol.when the buzzing sound is present ,it stops when i open the door,running or not.but starts up again when i close it,even happens occasionaly when ignition is off and no key in ignition.electrical problems are my worst night mare!!!!!!!! any one ever have these issues? in need of help.my battery is dead in the morning when this is happening .oh yea,and the o.d.light flashes occasionaly as well.im totally lost.HELP!!!!!!
Old Feb 8, 2017 | 03:33 PM
sessland's Avatar
sessland
A few of the things you mentioned might be caused by the dead battery.
My EX always acts crazy when the battery isn't 100%. Even though I had my batt checked at the local auto place and it tested ok, it was the problem.
Old Feb 8, 2017 | 04:40 PM
jakesterrocks
the battery was dead because of the dome light being on all night in 12 degree temps.it dose this when the battery is fully charged as well.as ive stated before it only dose this occasionaly.
Old Feb 8, 2017 | 05:17 PM
sessland's Avatar
sessland
I've recently developed an issue with the dome light staying on.
When the dome light is on and I try to drive it buzzes as to alert you that there is a door open. I'm pretty sure it's the back window sensor not making a good contact as it happens on and off.
You might want to try cleaning the contacst and double check to make sure they are well grounded. Simple and cheap
Old Feb 8, 2017 | 05:39 PM
jakesterrocks
I'll definitely try that.I'm not sure where the door sensors are located.I've looked on the driver door but didn't see anything. Are they in the doors?
Old Feb 9, 2017 | 10:42 AM
R&T Babich's Avatar
R&T Babich
The door open sensors are part of the latch assembly inside the door and look like this.
The left and right are different, not sure what is used in the hatch.
Do you have a "Door Ajar" light on the gauge panel?
Old Feb 13, 2017 | 02:37 PM
jakesterrocks
No.no light is on.it seems to only do it when its raining .
joe f350
23
Feb 1, 2009 11:26 PM
dfru
Jul 25, 2005 05:28 PM
mcastleberg
Electrical Systems/Wiring
Dec 10, 2003 10:58 PM
