Rear axle
Old Feb 6, 2017 | 04:28 PM
Will Dawson's Avatar
Will Dawson
Rear axle
i need to change the rear axle on my 1996 F-250. It is 2wd, 7.3, manual trans, full float, 3.55 ratio axle, C9 id on door placard. How can I find out, or does anyone know, what would be the newest model year axle that would be interchangeable. I don't know if there's a chart somewhere or if I'd just have to find and compare specs. Any help would be appreciated.
Old Feb 6, 2017 | 05:11 PM
97-psd's Avatar
97-psd
I believe 97 is about the newest. The super duties have a different lug pattern so it can get a little messy
Old Feb 6, 2017 | 05:42 PM
Will Dawson
Good to know. Thanks for taking the time to answer.
Old Feb 6, 2017 | 07:01 PM
Jarrett Campbell's Avatar
Jarrett Campbell
I have one you can buy.... Cheap!
Old Feb 7, 2017 | 12:02 AM
Kingkong0192's Avatar
Kingkong0192
Double that!
Old Feb 7, 2017 | 10:06 AM
Will Dawson
Are you located anywhere near central Kansas?
Old Feb 7, 2017 | 10:07 AM
Will Dawson
Originally Posted by Kingkong0192
Double that!
are you anywhere near central Kansas?
Old Feb 7, 2017 | 12:35 PM
Jarrett Campbell
I'm in Tyler tx
Old Feb 7, 2017 | 10:15 PM
nateairman's Avatar
nateairman
Anywhere near Vancouver BC?
A few of us may have some axels kicking around!
Old Feb 7, 2017 | 10:28 PM
Bubba Jones's Avatar
Bubba Jones
Oh I'd LOVE a 3:55 8 lug rear axle... but I would have to figure out the front axle setup so I don't have a mix-matched wheel setup. I've read swapping over a TTB 50 from the F-250s is about as much work as a solid axle in reference to my Bronco.
To the original poster, I'm pretty sure all/most Ford 8 lugs axles PRIOR to the super duty would be a direct fit, so as 97-PSD said, 97 is about the newest direct swap. I don't know why they decided to change the lug pattern with the super duty axles...
Old Feb 8, 2017 | 06:47 AM
Jarrett Campbell
Not all, the older trucks didn't have a VSS hole.
alexander.miller64
Dec 15, 2012 03:42 PM
fat al
Mar 9, 2004 12:03 PM
Kidd
Jul 15, 2001 04:57 AM
