Is the Cab and Box really "ALL" Aluminum, or is there some steel too for crash protection?
Just curious if I have to have anything treated / coated to prevent rust?
It's those hidden parts of steel that would concern me, and I don't want to put the blinders on thinking I'm good for 20 years "Cuz the body is aluminum", and some component rusts out after 8 years.
You have your truck back now? Everything fixed?
Here you go
http://a.co/6UWtV2D
http://a.co/6UWtV2D
Here is a link to the testing performed on the 2017 Super Duty....
https://www.youtube.com/watch?v=u_ii...&feature=share
The 2017 Super Duty is the only truck in the 3/4 ton and higher class to rate 5 stars. Not only for frontal crash, but also side and rear. Its amazing that the front doors still opened without cutting or prying after an impact like that. The nay sayers of the aluminum body have been proven totally wrong.
If you watch the NHTSA tests of the Dodge/Ram trucks, they actually crush so bad that the driver dummy had its foot crushed and pinched and it had to be extracted from the truck with severe leg injuries.
The 2017 Super Duty 2WD got the overall 5-star rating while the 4x4 only got 4 stars due to higher rollover risk.
In the testing, you can see a couple of things. One, the top of the bed is closer to the rear cab wall than the bottom of the bed...which would suggest some frame bending. Two, the passenger front window comes off its track and actually flies up partway during the collision.
Overall, probably the safest truck on the road and very safe among vehicles in general.
on
I was talking to a friend who works for Autoliv who is the maker of the airbags for the SD. He was deeply involved in the design from an early point when Ford provided only the cab from A pillar to C pillar for airbag development. The security in that portion of the company is crazy tight akin to the Manhattan Project he says. They take manufacturer prototype secrecy very seriously. But I digress.
A large reason why the 2017 did so well in the testing is because of a new technique they used in the design of the driver airbag. The problem with most of the small offset crash tests is that the driver tends to hit and glance off the steering wheel airbag to the left. They effectively squeeze in between the wheel and the curtain airbags and suffer injury. The new airbag design in our 2017's provides an extended bag that keeps the driver from going into the corner. It's amazing to hear this from a designer/engineer's perspective. He also said that the new bags are "Egggggsssssspensiiiiive". Safety comes with a price tag so we need to factor that in when comparing last year to this year.
He also told me that the NHTSA will be introducing a new and much more difficult test to pass. All the testing has been done at 35 mph and they are changing that to 55 mph. Yikes! I always thought the small offset was about as insidious as it could get because they purposely line up the impact point OUTSIDE the frame rail and typical crumple zones. This means that the fender and wheel and steering components have to absorb all the impact energy. He said that the Ford does really well on this test because it's steering and suspension components are a lot larger and stronger than the other makes. I asked about the Aluminum but he didn't know there was any data on that yet.
Just kind of interesting and a peak at the future.
