Power steering questions
Old Feb 3, 2017 | 09:05 PM
tinman52's Avatar
tinman52
Welder User
I'm replacing my 79 F250's worn out p/s box with a better used one. What fluid do I need to use? What did they originally come with, ATF or p/s fluid?
The nasty stuff that was in my pump looks and smells like ATF....
Also my return hose to the pump is kinda swelled and I'd like to replace it. Is this a special type of hose? Or will any old hose work?
Thanks
Old Feb 3, 2017 | 09:12 PM
PapaBearYuma's Avatar
PapaBearYuma
Thanks
My manual says ATF, although the Ford engineering number is different for a/t atf and p/s atf
And I'd use standard fuel hose for the return
Old Feb 3, 2017 | 10:35 PM
tinman52's Avatar
tinman52
Welder User
Do you suppose that would be type F fluid, or Mercon? Or does it matter since the system is empty now?
Also, how much fluid does the system hold?
I plan on getting a shop manual, thanks for your patience
Old Feb 3, 2017 | 10:53 PM
redcreekauto's Avatar
redcreekauto
Type F should be fine.
Old Feb 3, 2017 | 11:06 PM
DB429SCJ's Avatar
DB429SCJ
Power steering hose is available at NAPA.
Old Feb 3, 2017 | 11:12 PM
Ancona's Avatar
Ancona
Yes, type F is what's listed.
Old Feb 4, 2017 | 02:05 PM
tinman52's Avatar
tinman52
Welder User
Thanks for the replies and info!
Douglas DC-9
17
Oct 6, 2022 05:58 PM
missing my excursion
Oct 13, 2015 03:59 PM
TheKirbyMan
Nov 1, 2012 05:04 PM
redman84
Nov 22, 2010 11:46 AM
Bruce R Leech
Apr 8, 2007 12:07 PM
