Lift, wheels, tire complete!!
The lift is 3.5" up front (2.5" Icon coil and 1" PMF bottom mounted spacer)and 2.5" in the rear. It's a PMF Alpha lift with adjustable 3 link arms in the front, adjustable trackbar, front sway bar end links, PMF fox dual steering stabilizers, and fox 2.0 resi shocks. new 5.5" rear block w/ air bag tang, bottom mounted stage 2 rear traction bars, firestone 2600 air bags, air lift wireless 1 compressor. Wheels are 20x8.25 Fuel cleaver Dually wheels in the rear (-115mm and 227mm offsets) with a 20x10 (-19mm offset) srw wheel up front, tires are 37x12.5x20 Toyo RT's.
During install we found on the passenger side there is a major conflict with the B&W hitch and the rear shock. If you're planning on installing aftermarket shocks make sure you do it before installing a B&W hitch.
I knew I would be the guinea pig on the compatibility between the Firestone air bags, and the B&W hitch. After several conversations with Ride Rite and a few of their suppliers I was assured they were compatible. Well that was not the case, we had to cut the factory hitch lever, modify the bed, and custom weld a new lever to work with the bags. I know I could have gone with the Air Lift bags that sit on the bump stop tang, inboard of the leaf springs, but I like the stability of the bags mounted on top of the leaf springs. We also found the hardware that is supplied with the air bag kit is not long enough to reach the bottom overload spring and had to be modified.
I like it!!!
A couple of questions
1- why single wheels on the front I know wider stance did you remove the dually hub adapters I thought the bolt circle was different. Will you not get pulled over for the tires not being covered (front and rear)
2- why are the u bolts round at the top should they not be square
Jbair14,
Doesn't the front SRW wheel require you to carry two spares?
Also, I'm curious about your comment about stability of bags over springs vs. inboard the springs? Not that I can do anything about it with my current truck, but...
- I feel no instability even with a fairly heavy load over the axle...
- Have you experienced instability with AirLift?
- Or is this just a 'in general' thing that is known and accepted by everyone (except me)?
Please help me understand.
Thanks!
Thanks!
Jbair14,
Thanks!
Thanks!
I've just heard from multiple people the further out the bags are the more stability they'll provide. I ran on top of leafs on my 6.4 and inboard on my '15 6.7 I actually liked the setup on my 6.4 better. For a lifted application in my opinion over the leaf is easier to set up.
