2000 ccsb 4x4 vibration
Old Feb 2, 2017 | 10:45 PM
biggdirty7.3's Avatar
biggdirty7.3
Under Acceleration my truck vibrates. If I lug it in od at low rpm it feels like a galloping more than a vibration . Has anyone had these sorts of issues. I'm certain it isn't u-joints because I had them checked . Thank you in advance.
Old Feb 4, 2017 | 01:30 PM
crop harvester's Avatar
crop harvester
I don't know if Your Mechanic pulled the drive line,but that's the best way to check out each U-Joints,slip yoke splines, carrier bearing for problems,also look over rear differential pinion & suspension for problems,such as loose leaf spring bolts etc.
Old Feb 4, 2017 | 01:32 PM
biggdirty7.3
i will be replacing the transmission soon and I will check everything then
mriplaybass
Mar 2, 2008 08:36 PM
shadows4
Sep 25, 2007 07:29 AM
KathyB
1997 - 2003 F150
Dec 11, 2006 11:28 AM
dj123
Nov 10, 2006 09:44 PM
Fordbronco69
Jan 4, 2006 11:15 PM
