Sponsored by: Real Truck
Electrical problem
Old Feb 2, 2017 | 07:20 PM
Roger White's Avatar
Roger White
Electrical problem
I have a 2008 Ford F250 Super Duty 5.4 liter automatic trans 4X4 with 158000 miles. Here's my problem when I start my truck it says check brake systems, door is ajar, my blinkers work on the outside of the truck but not on the dash, and when I turn my vehicle off and the keys are removed my instrument lights stay on. I have pulled all four wheels and the brakes appear to be good and don't act up at all, I've checked my brake fluid and it's fine I was told it's most likely my battery so I did a load test and it was low I only had a little over 300 cold cranking amps I put a new battery in it not the cheap one and not the most expensive I went with a mid-range with 960 cold cranking amps. This problem is intermittent sometimes when you're driving it just goes back to normal and sometimes it will show all of these lights for a month or more and I have to disconnect my battery at the end of each day for a couple weeks sometimes and sometimes it only does it for a day or two. I put it on my cheap scanner and it didn't show anything so I took it to my buddy who has a really nice Snap-on code reader and his shows nothing wrong, both times we did these tests we did it when it was acting up. Has anybody ever experienced anything like this and if so what was the problem?
Old Feb 3, 2017 | 10:43 AM
Mike1's Avatar
Mike1
Do any work it recently? Aftermarket radio or stock? Could be the GEM (BCM) or related wiring. Just guessing though.
Old Feb 3, 2017 | 09:07 PM
Roger White
no truck is 100% bone stock nothing's ever been altered or added that I know of I purchase the truck used a few years ago and this is the only problem it's ever given me
Old Feb 3, 2017 | 09:14 PM
Roger White
I did change my tires and rims to a 2015 Lariat model and my tire pressure light stays on but I understand why that is but I did that within a month of buying the truck
Old Feb 3, 2017 | 09:26 PM
Roger White
I also noticed my rear cargo light is staying on for about 15 minutes after I get out of the truck and lock it up
linekin
Apr 22, 2018 06:59 AM
Publix1355
2009 - 2014 F150
May 1, 2017 07:23 PM
Horsecamping
Aug 14, 2015 11:23 PM
countryboy711
Jan 6, 2010 09:13 PM
Ingy
Jun 28, 2004 06:52 PM
