Body swap
Old Feb 2, 2017 | 01:19 PM
kalebc2's Avatar
kalebc2
Body swap
Will a 2wd single cab long bed body of a 1976 fit on a 1979 same body style but 4x4? Thanks
Old Feb 2, 2017 | 01:26 PM
CelticOne's Avatar
CelticOne
Regular User
Since your 76 is a 2wd it (thus not a "high boy") the frame widths are the same as the 79. If you are swapping a regular cab long box on to a frame that held the same you should have no problems. Rad supports would have minor differences (round vs square headlights).
Old Feb 2, 2017 | 01:41 PM
kalebc2's Avatar
kalebc2
I plan on swapping everything but the 2wd components to the 79 4x4
Old Feb 2, 2017 | 08:46 PM
paredneck33's Avatar
paredneck33
You will be fine. But just be sure to reuse the filler neck(s) from the 76 truck. The 76 truck uses the round exposed fuel cap, where as the 79 uses a square fuel door. So the filler necks are different between the two styles. Other then that everything is a direct bolt swap.
mitch9705
Mar 30, 2006 09:18 AM
hell on wheels
16
Nov 8, 2004 11:29 PM
flatblack79
Aug 5, 2004 07:39 PM
scottie2hottie
Jun 11, 2004 10:23 AM
mrfusion70
Paint & Bodywork
Aug 25, 2003 11:46 AM
