OK guys my brother's 91 f250 is giving us fits and driving us nuts. We just finished rebuilding the engine and are trying to get it to start.
You crank it over and it cranks slow with a jump or not and it is a brand new battery. Once in a while it cranks a bit faster but still won't start. Checked fuel pressure and it is within spec (better be since it has Rand new fuel pumps). Checked fuel injectors with mood light and working good. Checked spark and it was a bit erratic so I put a coil I know is good as it came off my 88 f150.
Went to pull codes and nothing. It makes the clicking sound of the relays but no codes come up. I mean nothing at all not even a blinking light. Put a brand new computer same issue still.
Inside no battery gauge does have a battery light though, no cel, no rear anti lock.
Going to try my good old cluster with no tach from my 88 but doubt that will fix the issue at hand.
Seems to me like the timing is out but I did check it again and dead on tdc. It wants to start once in a while but won't.
Truck is a 91 f250 460 e4od 4x4 that got rebuilt completely stock minus F3te heads.
Any help is appreciated
Trav
I meant I got it to TDC and while turning over I turned it back and forth to help it start with no luck. No valve clearance wasn't checked because the specs of the rebuild are a stock 94+ 460.
Trav
Does the lower half of the cap have the raised "1" inside? Yes?
Pull #1 plug & turn over by hand with breaker bar to make sure its it is in the ball park (finger over hole, pressure build up rather than vac) timing wise while watching balancer marks.
Verify that rotor is fractions of inch BEFORE the #1 in the cap & 10* on the balancer.
Pull the SPOUT plug.
Hard to turn over with good battery is sometimes un-evenly tightened transmission bell housing bolts.
Trav
Clean the pins on the diagnostic port. Use contact cleaner or if you need something more aggressive use a finger nail file.
If you're sure your distributor shaft is not 180 degrees off, you can set the timing with a timing light by cranking the engine with the starter.
X2.....the symptoms (minus the no code issue) point to stabbing the distributor 180 degrees out. Remember the crankshaft rotates twice as part of the engine combustion/exhaust cycle.
Got a couple things figured out. Battery was bad wouldn't take a load. New battery and she started right up got a few more tuning items to do but it runs. However no cel or tach on the cluster. Checked the prongs at the computer and everything looks fine. Test light in the bulb socket and still nothing. New cluster that I know is good without a tach (was in my 88 but installed a tach cluster) and no cel still.
Trav
Start it up and you hear a grinding noise near the starter replaced the starter as I thought that it was acting up and same. Only makes the noise in park and neutral. Put it in gear and it acts like the transmission is slipping in drive and reverse. No OD light at all and still can't pull codes.
I am almost 100% sure the torque converter is locking in or unlocking causing an issue and I believe it is electrical. No ammeter, coolant gauge, tach, oil pressure gauge or other lights. High beam on the cluster works.
Trav
In drive it acts sometimes like it is going to die until u give it more gas again
I am almost 100% sure the torque converter is locking in or unlocking causing an issue and I believe it is electrical. No ammeter, coolant gauge, tach, oil pressure gauge or other lights. High beam on the cluster works. Also it won't idle down.
Trav
Trav
That sounds like your ignition switch is probably feeding power to the fender mounted solenoid when it shouldn't be. You can check that by pulling that little slip on wire off of the fender mounted solenoid. If pulling that slip on wire off stops the grinding noise, you will know where to look for the fix. At any rate I would address that problem first before you wreck something worse.
What I'm saying is your starter is likely staying powered any time the transmission is in park or neutral.
