transmission vacuum line
Old Jan 30, 2017 | 11:29 AM
red66rider's Avatar
red66rider
I was wondering if anyone makes a pre bent line for the c6 trans and our trucks? I have a 66 f100 with the straight 6. I have done a quick search and pretty sure there isn't anything out there, since everything came up for the mustangs; if that is the case is there anything close that can be used from other years etc? thanks for the help. in the end I will need a vacuum line for my swap just figured I see about another bent/length. thanks.
Old Jan 30, 2017 | 02:43 PM
Crop Duster's Avatar
Crop Duster
If you are getting it from a salvage yard the transmission should have a vacuum line on it already. If not you can make your own. All you need is vacuum to the modulator. The real problem is getting the correct kick down rod. Those things are very difficult to make and usually get thrown away.
Old Jan 30, 2017 | 04:48 PM
red66rider's Avatar
red66rider
trans came from CL and had it rebuilt so been gaving to piece everything together.... what is the kick down rod you speak of?
Old Jan 31, 2017 | 04:24 AM
Crop Duster
C6 linkage
It's the yellow zinc plated rod in the picture that goes from the carb to the kick down lever on the trans. Without that the transmission will short shift and it won't downshift under a load. Basically the drivability will suck.
You say you got the trans from craigslist. Did it come from a truck? Are you planning on using the column shifter or a floor shifter?
Old Jan 31, 2017 | 12:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1978 was the first year that the C6 was available with 300/302 engines in F100/150 & F250 300. But the C4 was also available thru 1981.
Prior years, back to 1965, only the C4 was available except in F350's with 300 I-6 which used MX C-O-M (1965/72) or FMX (1973/77).
240 cancelled at the end of the 1974 model run.
Old Jan 31, 2017 | 03:10 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I've got a couple of the original kickdown rods for the MX COM with 352 2V. They look about the same overall as what CropDuster shows on his, but they can vary a little as far as bends and length goes so you want to make sure you get the correct one for your application. For me it is -
C5TZ-7A187-B .. Engine Mounted Accelerator Shaft To Transmission Throttle Control Outer Lever Rod
Old Jan 31, 2017 | 08:23 PM
red66rider's Avatar
red66rider
So the kickdown rod is similar to a kickdown cable? The trans was originally in an econoline with a 300... im using a floor shifter. B&m starshifer to be exact.
Old Feb 1, 2017 | 01:07 PM
red66rider's Avatar
red66rider
if the kickdown cable is same as the rod, I bought a universal kickdown cable.... is it a must to install the kickdown? also, what is the exact size line and fittings to use for the vacuum line? also when I was searching vacuum line, stainless steel braided line came up as an option for vacuum line connection, is this a possibility for this application? this is all new to me/a learning experience so sorry for all the questions, just really want to get this thing finished up and driving.
Old Feb 1, 2017 | 02:42 PM
Crop Duster
It will move down the road without the kickdown, but only just, and not very well. Yes, you need it hooked up and properly adjusted. The modulators use a 1/4 inch rubber push on hose fitting to connect to a 1/4 inch solid line to the vacuum source. No clamps used or needed. I used aluminum line mostly because I had it already and it's easy to bend. You can just make it out in the picture I posted next to the dipstick.
Old Feb 1, 2017 | 09:32 PM
red66rider's Avatar
red66rider
Thanks Crop. I will see about getting some brake line tubing this weekend and try my shot at bending it up. What kind of fitting would i need for the exhaust manifold? Assuming just a brass barbed fitting?
Old Feb 2, 2017 | 03:25 AM
Crop Duster
I'm sure you meant to say INTAKE manifold. Yes the brass fitting will work fine. The trans just needs full manifold vacuum.
Old Feb 2, 2017 | 07:23 AM
red66rider's Avatar
red66rider
I will post a picture later today or tomorrow where i was thinking of tapping into to see if its the correct location
Old Feb 2, 2017 | 08:04 PM
Fords & Whalers's Avatar
Fords & Whalers
I have a C-6 in my 1965 and am using 1/4' fuel line from the intake manifold to the modulator and it seems to work fine. It's about a 3' run and I'm happy with the RPM shift range. It took a little fine tuning between the kickdown cable and the modulator, but its right where I like it.
Old Feb 4, 2017 | 08:19 AM
red66rider's Avatar
red66rider
so checking the local auto parts websites im not having luck with the 1/4" aluminum fuel line. hate to order it from like summit which is like 25ft or so. I think I seen speedway motors had 10 ft for about 15 bucks shipped.
really appreciate all the help
Old Feb 4, 2017 | 10:09 AM
Crop Duster
It can just be steel line. You should be able to get it at any parts house. And you should be able to borrow a tube bender from Autozone or O'Reilly's. if you don't have one.
