Front open differential?
Old Jan 29, 2017 | 10:15 AM
Zybane's Avatar
Zybane
Thinking about ordering a 2017 SD. But from what I can tell they all have front open diffs? Obviously that is no good for any type of off-road.
From what I understand ARB offer's air lockers for the front Dana 60. Anyone have a clue if that would work in a 2017 SD? Not sure if they did any axle changes from the previous SD.
Old Jan 29, 2017 | 10:28 AM
Conanski's Avatar
Conanski
99% of all 4wd trucks sold came with open front diffs, the reason is that with a locked front diff the truck becomes almost uncontrollable, when both tires have traction the vehicle just wants to go straight ahead and it will pull hard to the side with traction when the surface is uneven and slippery so you simply cannot use it on packed or paved roadways and at speed. So what you'll find is a front locker is really only useful in the most extreme offroad conditions and once you're out of that you will want to unlock it.
Old Jan 29, 2017 | 10:33 AM
Sleepyguy's Avatar
Sleepyguy
Correct me if I am wrong but can you not manually lock them? Or does that simply engage the 4x4 system and by pass the in cab selector ****.
Old Jan 29, 2017 | 10:35 AM
bronc71's Avatar
bronc71
He's talking about an arb air locker that you can unlock for a normal open dif
Old Jan 29, 2017 | 10:45 AM
Zybane's Avatar
Zybane
Ya, I am tracking. I know a locked front diff is bad for street use. But I have fairly decent off-road requirements. Off-road, a front open diff just means your 4WD truck is 2/3 wheel drive on anything difficult. Heck, I'd even take a Torsen if it was available.
I would be coming from a Power Wagon that has electric lockers in the front too. But I really like the new SD and diesel.
Oh and that also begs the question, do these aftermarket 2017 SD winch bumpers work with the diesel and I assume associated inter-cooler? And not block all the air?
I need a winch and some sort of non-open differential in the front. Aftermarket is not problem for me.
Oh and also when I built a Platinum SD, why is there no "FX4" package? It lists skid plates and rear E-locker as separate lines.
Old Jan 29, 2017 | 10:46 AM
bronc71's Avatar
bronc71
I'm sure the front dif is the same
Back in 1990 "I was 20yrs old"and rebuilt a 71 bronco I changed the gearing to 4:10 and installed a Detroit locker front and rear that truck was a beast off road. Then came the 1st winter I had a company truck 1983 ford ranger 2wd but being 20yrs old that was not cool to drive that after work lol. 1st snowfall I took my bronco out for a cruise put it in 4wd gave that 351w a shot of gas going down a snow covered road and after doing what I think was 2 360's cause the front end was grabbing traction on both wheels I parked it for the winter and never drove it again in 4wd on a paved surface.
Old Jan 29, 2017 | 11:20 AM
mhoefer's Avatar
mhoefer
You might be better off without the electric rear locker too. If you are converting the front to an ARB, do the rear too. Reason I say thins is the rear locker electric shuts off at 30 mph. This would likely make wheeling tricky as tire speed would be an issue. That being said, depends on how you load it. Good weight on the rear and the locker will get you through a fair bit, essentially 3 wheel drive. The other thing I would think to consider is the diesel, she is HEAVY up front there.
When you go on the build site the FX 4 should show as included in some of the packages? Try building a platinum ultimate and see if it shows you get these additional options?
Old Jan 29, 2017 | 12:49 PM
coolidge54's Avatar
coolidge54
Same era I watched a guy come hauling *** out of a side street in the snow trying to make a turn onto the main 4 lane street in his big tired Bronco...he slid sideways across the street and slammed into the curb bending both his wheels doh!
Old Jan 29, 2017 | 02:09 PM
troverman's Avatar
troverman
The intercooler on the 6.7L Ford is air to liquid, not air to air like a Cummins or Duramax. It is located just inside the left fender behind the battery.
Biggest issue with aftermarket bumpers is if your truck has adaptive cruise control...moving or blocking the radar sensor can be a problem.
Any modern diesel truck used for off road can be a liability. The DPF tube can get crunched by rocks. I'd rather have the PowerWagon if I needed an HD truck for the kind of off roading that needs a front locker.
Many people *think* they need a front locker, but they don't. These trucks do have brake based traction control on the front wheels when 4x4 is engaged. That will help send traction to the other side if needed.
Old Jan 29, 2017 | 02:25 PM
6fordtrucks's Avatar
6fordtrucks
the FX4 is there for a platinum. I built the truck and as I went step by step there was no fx4, then after I finished, I scrolled up and there it was! That is how it shows up every time. Still that way
Old Jan 29, 2017 | 04:19 PM
Frantz's Avatar
Frantz
Keep in mind too there is a little more technology in the new trucks than the old stuff. So while it's an open diff, it's not quite worthless thanks to traction control. Same with the trucks without lockers (though for serious offroading or plowing the locker is nice). By applying breaking to a spinning wheel, improved traction is achieved. If you've ever driven an older tractor you've likely applied brakes to a slipping wheel to get out of a rut. Same idea, only automatic and much more precisely applied.
Old Jan 29, 2017 | 06:07 PM
Rutcutter's Avatar
Rutcutter
I would like to see the Locking front diff with the Sway bar disconnection option included with the FX4 option on both the 1/2 an 3/4,1 ton srw trucks..
Old Jan 29, 2017 | 07:29 PM
wb6anp's Avatar
wb6anp
Id also be concerned with off roading if in brush and it decides to go into regen, 1200 deg is enough to start a fire.
Old Jan 29, 2017 | 10:12 PM
Zybane's Avatar
Zybane
Ya, as much as I want a diesel and that low end grunt I think my Power Wagon just fits the bill better for me and my off-road requirements.
Old Jan 30, 2017 | 01:21 AM
willynilly's Avatar
willynilly
could you imagine all the knuckleheads running at highway speeds with the axle locked. the only for sure way to dummy proof it, is dont even offer it. ram has dummied theirs down the best they could but in doing so, it hurts the responsible person that could use 4hi elockers
