Dirty Knock
Old 01-30-2017, 06:44 AM
fordpride's Avatar
fordpride
fordpride is offline
Only use motorcraft gp's
Old 01-30-2017, 07:23 PM
fordman67's Avatar
fordman67
fordman67 is online now
True^^
Just say no to autolites!!!
Old 01-30-2017, 08:03 PM
Red97350's Avatar
Red97350
Red97350 is offline
Friends don't let friends use autolites in their Powerstrokes!
Red
Old 01-30-2017, 08:32 PM
muskydawg's Avatar
muskydawg
muskydawg is offline
I got her all back together today, with Bosch gp's, Ford ones were 4 days delivery, and twice the price!
The thing is, I think I can still hear some of the knocking noise... Definitely not as bad, and not all the time. When it does happen, it is at idle. When I pulled the harness off to the injectors at the valve covers yesterday, it looked like there slight oil residue in there. Should they be dry? Or some dielectric grease maybe? All the injectors seemed tight when I checked the mounting bolts. You can't get at the top bolt very easy, so I left them, when I found how tight the bottom ones were.
Should I try some kind of injector cleaner? I run dyed diesel in it, but I don't think that does anything does it?
Old 01-30-2017, 08:44 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
Where are you located?? I wasn't aware it was legal to run dyed diesel in any on-the-road trucks...
Old 01-31-2017, 08:19 AM
muskydawg's Avatar
muskydawg
I'm plowing ice roads with it.. so it's legal.. not "on-the-road"...
But, let's stick to the engine questions, and not worry about making a criminal out of me!!
Old 01-31-2017, 10:23 AM
fordman67's Avatar
fordman67
I have to say Bosch gp worry me. Its your truck but if it were me I'd be ordering ford/beru ones or diesel RX brand. Its your truck but just google search autolite issues...
Old 01-31-2017, 10:33 AM
knottyrope's Avatar
knottyrope
knottyrope is offline
Did you clean the FPR screen when you changed the filter? mine was clogged up with stuff.
I like the WOT in 3rd gear test for fuel pressure, if less than 40 you have an issue
I also bought this spring for the FPR as the old one was weak and bent with BB mod
Ford Powerstroke Fuel Pressure Regulator Spring 7.3 FPR F250 F350 95, 96 Diesel | eBay
Old 01-31-2017, 10:40 AM
muskydawg's Avatar
muskydawg
This might be a stupid question, but are Bosch and Autolites the same thing? Or, has everybody agreed that it is ford gp's or nothing?
Old 01-31-2017, 10:42 AM
muskydawg's Avatar
muskydawg
Ford Powerstroke Fuel Pressure Regulator Spring 7.3 FPR F250 F350 95, 96 Diesel eBay
I didnt check the screen... I didn't know there was such a thing! Thanks for the heads up, I'll check it out.
Old 01-31-2017, 11:08 AM
knottyrope's Avatar
knottyrope
since joining here I have seen everyone say use Ford ZD11 GP only
Old 02-12-2017, 07:09 PM
muskydawg's Avatar
muskydawg
Well gentlemen, a quick follow up. In the end, I ended up taking the ol' girl in to the shop. Turned out that it was actually a broken flywheel. Crazy!! I've never heard of that before, broke all the way around the center bolts.
Anyways, just wanted to put some closure to this thread. Thanks again for all the feedback.
  #28
Old 02-12-2017, 08:49 PM
Red97350's Avatar
Red97350
Red97350 is offline
So, you have a standard then? Good thing it didn't grenade on you.
Red
Hieu_T
1999 to 2016 Super Duty
08-10-2019 09:36 AM
kbarbee95
35
09-24-2015 06:10 AM
wburge
6.4L Power Stroke Diesel
02-15-2012 10:27 AM
FLYBOY07
04-10-2008 08:12 AM
deetown
05-03-2005 07:38 PM
Quick Reply: Dirty Knock
