Steering Column
Old Aug 28, 2003 | 12:46 AM
msgjvh's Avatar
msgjvh
Steering Column
I have a 77 F100. It keeps shifting out of Park and into Reverse. Took the steering column apart tonight and realized there is likely no chance of a rebuild. Everything is really worn. How hard is it to find a non tilt automatic column and then replace it?
Old Aug 28, 2003 | 01:10 AM
mt78Lariat's Avatar
mt78Lariat
Steering Column
They are around,, you can use from 73- 79 ,, what part is worn??
Old Aug 28, 2003 | 04:04 AM
msgjvh's Avatar
msgjvh
Steering Column
When it was pulled apart the interlock between the Shifter and the rear plate on the column were very worn. One of the screws that hold the plate in place was broke. The shifter itself looks to be worn where it slides into that plate. Between all the I think its easier to find an entire column.
