Seat belts for 1954 F100
Let's consider the context. Federal guidelines doesn't recommend lap belts, but that is what we are talking about. I think that the cab floor in a '54 F100 squeezed between a couple of 1-1/4" OD 1/8" thick case hardened steel washers will do the job.
Each person has to ask themselves how much is enough. And they should base that on where they are driving, at what speeds, and how much. The driver with three air bags aimed at his head will tell anyone with less that they are at grave risk.
Sorry, since I design and sell the stuff I guess I get a little on the overboard, overbuilt side. Of course we have to go by certian rules (because we are reselling the item) that are sometimes silly or just plan impossible, when dealing with a truck that is now 50 years old. Most people building thier own truck are a lot more safety minded that ever these days and I have seen some wonderful installations. Didn't mean to overstep.
You all know I love controversy so I might as well jump right in. 1 1/4 fender washers is the wrong answer!!!! I just completed a Defensive Drivers Course from the National Highway Safety Council yada yada yesterday.
I'll get the specific statistics tomorrow for the resident physics experts to crunch. The force on the belt mounting points when an Effie slams a stationary object is just unreal. I'll get the specifics. It's many thousands of pounds for a 200 pound driver and a 50 mph collision.
Well this is educational and I like it!!
I'll be interested to hear what the Physics major has to say. Personally, I like to overbuild on safety, so I welded 4"x5" plates of 14 guage steel, top and bottom. at 90 degrees and then welded a heavy washer and nut to that on the bottom side.
In the upper corners of the cab I installed 1/4" plate after welding a nut to the back side.
I didn't do the math, just intuited it I suppose!
"53Merc
M100
"53Merc
M100
I am sure the force excerted on the bolt at the floor mounting point is unreal 1 1/4 just doest seem big enough. I looked into something at speedway motors and they have a kit that uses a 2 1/2 OD washer. These guys sell all kinds of items including racing equip so I like to think they have an idea of what will work safely.
Because they sell all kinds of racing equipment, they use 2/1/2" washers on their four point racing harnesses.
But this thread started as a discussion regarding lap belts on a 54 F100. My Effie has a 4.86 rear end; I'm in high gear at 20 MPH and I top out at 45 MPH. So, I rarely go on the highway. My main concern is staying in front of the steering wheels and pedals. I think the 1-1/4" diameter 1/8" thick case hardened washers will do that for me.
I didn't say that the washer was acting alone to do the job. We are talking about the washer because that was what the original question asked. The job of the washer is to distribute the force load over it's area.
And, it is the radius that get's squared in the area formula. So bigger is better. That's why 53Merc is using 4" X 5" plates. Each of us has to decide how much is enough in our application.
#29
OK, according to the NHTSC, here’s what we need. Assuming a 220 pound driver in a 30 mph collision with a stationary object, the force applied to the safety belt is 4,400 pounds. Assuming the force is evenly applied to both anchor points, with a 2 point safety belt, we need each mount point to withstand a 2,200 pound force.
My questions are:
Would it go up by a simple factor of 2 for a 60 mph collision?
Would the numbers go up for a head-on collision rather than colliding with a stationary object.
Does the safety belt webbing stretch absorb some of the energy and reduce the amount of force applied to the mounting point?
I at one time considered attaching to the transmission crossmember. I have re-evaluated that logic now that I have considered the unimaginable force or a cab launch on my waistline.
I don't know what this means in washer diameters.
OK, George, don’t blow us away with 2 pages of equations if you can help it.
My questions are:
#30
Originally posted by fatfenders
... Would it go up by a simple factor of 2 for a 60 mph collision?
... Would the numbers go up for a head-on collision rather than colliding with a stationary object.
... Does the safety belt webbing stretch absorb some of the energy and reduce the amount of force applied to the mounting point?
... I at one time considered attaching to the transmission crossmember. I have re-evaluated that logic now that I have considered the unimaginable force or a cab launch on my waistline.
... I don't know what this means in washer diameters.
... OK, George, don’t blow us away with 2 pages of equations if you can help it.
For 5,000 lbs, you are not going to get a failure using a grade 5 or grade 8 bolt, at least 5/16" diameter, in either shear or tension. Standard grade 5 and 8 nuts and washers are designed to handle the same load as the bolt.
As 'fenders pointed out, the weak link is the sheet metal the bolt is attached to and, potentially, any hardware that connects the bolt to the belt material. To know FOR SURE, you'd have to do a series of tests on an actual cab to see what size washer it takes to avoid significant distortion of the sheet metal. Note that you don't need to pull the washer through the sheet metal to have failure. If the sheet metal bends three or four inches without the washer pulling through, you may still hit your head on something do to the distortion.
I've already decided to put in a couple of 6"x6"x1/4" steel plates with a 2"x2"x1/4" square tube welded between them. It's simple to do for me because the cab is off and I'm redoing everything. The square tubing means that you'd have to pull the entire bottom/rear edge of the cab inward to have a failure.
Sometimes I fool myself by underestimating the forces involved in various situations. I think the numbers from various folks in this thread give all of us an idea of what those forces are for seat belts. Everybody will have their own way of dealing with the problem - but at least we all know what we are up against.
