Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1985 f600 forestry package (Aerial lift/chip box) project
Old 08-17-2017, 06:39 PM
Diymechanicmike's Avatar
Diymechanicmike
Diymechanicmike is offline
And both vac ports have suction should I decel throttle screw?
  #107
Old 08-17-2017, 06:41 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
What's the line? 0 degrees? Are there marks for 5, 10, 15, 20 degrees? Should be 5-10 BTDC.
That's with the vacuum advance on the dizzy disconnected if it isn't still.
  #108
Old 08-17-2017, 06:51 PM
Diymechanicmike
Took like 30 trys to get that pic on my phone but that's the timing
  #109
Old 08-17-2017, 06:53 PM
Diymechanicmike
That line stays right there with or without vac hooked up
  #110
Old 08-18-2017, 07:02 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
What is the chalk mark on?
Is there vacuum on the port? I wonder if the vacuum advance diaphragm is shot.
  #111
Old 08-18-2017, 08:07 AM
Diymechanicmike
What is the vac advance diaphragm and was gonna ask the vac line coming from back of carb diaphragm should this be hooked up sumwhere I think u said egr valve
  #112
Old 08-18-2017, 08:08 AM
Diymechanicmike
Bout to check the mark position and which port u talking bout vacuum being there
  #113
Old 08-18-2017, 10:28 AM
Diymechanicmike
It looks to me like the mark is at about 8degrees
  #114
Old 08-18-2017, 10:29 AM
Diymechanicmike
So when I had the timing light going the pointer was pointing at I'd say about 15 degrees cuz it was about a quarter inch past the line
  #115
Old 08-19-2017, 08:28 AM
Diymechanicmike
Nvm that last post was totally wrong the pointer is at the 0 or maybe even negative a bit look at pics of timing light pic and jus pic of marks
  #116
Old 08-19-2017, 08:40 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
yeah, I'd bump that a touch - loosen the hold down for the dizzy and rotate it CLOCKWISE slightly and recheck. For that motor, it could even be slightly higher than the mark.
What I bet happened is, someone timed it with the vacuum advance connected to vacuum-at-idle which is wrong.
Back to the distributor's vacuum advance diaphragm - take the distributor cap off, and supply vacuum (suck on the hose, if you have to) and see if the vacuum advance works, and stays with steady vacuum - in other words, the diaphragm doesn't have a tear/rip/hole.
  #117
Old 08-19-2017, 08:53 AM
Diymechanicmike
I should spin dizzy with motor running right? Cuz I actually tried to loosen that and spin with engine off ,and it wasn't acting like it wanted to spin thought I was gonna break sumthing trying to spin it so I figured it might jus need to be running but didn't wanna do that til I ran that by sumone with a lil more knowledge
  #118
Old 08-19-2017, 09:40 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
It's always a good idea to make sure the dizzy is loose with the motor OFF first.
First, make a mark on both the dizzy and the intake/engine so you can put it back where it was if it moves too much while you're trying to get it moving.
Sounds like it's stuck. You loosened the hold-down?
  #119
Old 08-19-2017, 01:58 PM
Diymechanicmike
Yes I took hold down off and didn't move and I did mark the dizzy/intake
  #120
Old 08-19-2017, 02:53 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
spray it with penetrating oil. Where the dizzy meets the intake/engine.
Quick Reply: 1985 f600 forestry package (Aerial lift/chip box) project
