Sponsored by: Real Truck
2006 5.4 what to do??
Old Jan 24, 2017 | 04:22 PM
Banshee25's Avatar
Banshee25
Originally Posted by fordf2501
well first before you call 5star i would be doing any maintenance that the truck needs like plugs and fuel filter and air filter checking fluids and belt. to check to see what type of gears you have look at the door sticker. just google ford axle codes click on the first link and find your axle code to see what gears you have for example my axle code is C2 and on the chart it says that i have 4.10 gears with a dana 60 and limited slip diff
thanks but I've taken care of all the necessary maintaince issues. I know that I don't have a limited slip for one and can almost bank on the fact I have 3.73's
Old Jan 24, 2017 | 05:02 PM
Ron94150's Avatar
Ron94150
Originally Posted by Banshee25
it's not that my truck won't do what i ask it's just that it doesn't do it very fast and when it does it's not very enjoyable not looking for a race truck but would love to get a little bit more performance out of it as to reduce the itch to buy a new 6.7
also I'm currently running to 65's on factory wheels looking to put on a set of 20 x 10's with 33's on there is the recommendation still 410s or possibly a higher gear ratio ??
I would go 4.56. If your needs don't include much hwy, or you are always loaded, I would strongly consider 4.88. This also allows for 35's for when the 33's get to small.
That would also be referred to as a lower gear ratio, not higher. The higher the number, the lower the gearing.
Old Jan 24, 2017 | 05:09 PM
Ron94150's Avatar
Ron94150
I know you didn't ask for my opinion, but I think a set of 0 offset black wheels would set it off nicely.
dulas101
Aftermarket Products
Jan 13, 2019 08:39 PM
Mike94ZLT1
Dec 15, 2018 02:23 PM
huckster
2004 - 2008 F150
Jun 25, 2015 02:16 PM
calgary man
Mar 20, 2012 07:32 AM
bigbadassfords
Modular V8 (4.6L, 5.4L)
Feb 18, 2012 03:11 PM
