Paint scheme correct?
Old Jan 21, 2017 | 10:20 PM
2bocat's Avatar
2bocat
Looking at buying a 66 F-100 with VIN tag that shows color JM. Is the white roof only with red body a standard JM paint scheme, or has someone painted over the white hood and top of bed rail and such like I normally see?
Old Jan 21, 2017 | 10:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 2bocat
Looking at buying a 66 F100 with Warranty Plate COLOR code JM (J = Rangoon Red / M = Wimbledon White).
Is the white roof only with red body a standard JM paint scheme? No. Or has someone painted over the white hood and top of bed rail and such like I normally see? Probably.
It might be a correct paint scheme, might not. I've only seen about 3 trucks painted this way...and all were here on FTE
JM: Primary color (J) listed first. If the roof was white originally, COLOR code would be MJ and I've never seen a COLOR code of MJ
Truck has definitely been repainted and that red doesn't look like Rangoon.
Mirrors mimic a type that was introduced in 1973, but these mirrors are el cheapo gypo's. Antenna (at least the mast) isn't original either.
Look at it carefully for rust. It may be in dry eastern WA now, but how long has it been there?
If the DSO code is 74, it was ordered from Seattle.
Old Jan 22, 2017 | 05:36 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Here's the info on the 3 paint schemes in 1966. Note: Two-tone = tu-tone.
F100 2WD and 4WD; F250 2WD
PAINT:
Standard: Single Standard Color
Optional: Two-Tone Regular - All Cab Models
...............Two-Tone Deluxe - Stylesides
...............(Includes Body Side Moldings and Bright-metal Taillight Bezels)
F250 4WD and F350
PAINT:
The regular two-tone was the only two-tone choice for non-styleside beds and wrong bed, but was also available with new style styleside beds.
The deluxe two-tone was only available on new style styleside beds - and required the body side moldings to cover the paint line.
Body side moldings were optional on the regular two-tone paint scheme with new style styleside bed, like the truck pictured above.
The truck pictured above is the regular two-tone paint scheme. No matter which scheme the primary color was listed first, so JM would be correct for both schemes.
Old Jan 22, 2017 | 06:14 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Here's a factory photo of a Custom Cab F250 2WD with the regular tu-tone paint scheme and body side moldings. This one also has the stainless steel hub caps.
Old Jan 22, 2017 | 09:33 AM
2bocat's Avatar
2bocat
Thanks!
Y'all are fantastic. This is going to be my 5th slick 60 and I'd just never run across this paint style. Thanks much!
Old Feb 7, 2017 | 07:17 PM
664x4drvr's Avatar
664x4drvr
Origional Paint
[ATTACH]173458[/ATTACH
My truck with Factory Paint
6t6merc
Mar 10, 2013 08:38 PM
tpdaniels
Apr 18, 2011 04:47 AM
Futuresweets-10
Apr 24, 2010 08:55 AM
Squam74
Jul 1, 2009 10:41 PM
reveye
Apr 10, 2007 02:58 AM
