5th wheel hitch advice
Old Jan 20, 2017 | 11:40 PM
workingdan's Avatar
workingdan
Hi guys, ordered a 17 F350 long bed and looking to get a new hitch. I think I want a demco hijacker (8550033) for my factory prep kit. I like the wrap around jaw. I had a 18k ford (Reese) im my last truck and didn't care for it. too noisy. I know alot of people like the anderson and pullrite tripod hitch. I do not like the adptor that needs to be installed onto the king pin or the fact that it could dent my aluminum bed.
Anyone use a demco? Do you like it? Any negatives? Any alternatives?
I tow a 16 fuzion 414 (43.5 L) 18K lbs
Thanks
Old Jan 21, 2017 | 01:43 AM
cyncwby's Avatar
cyncwby
Well for that big of a trailer I would have ordered a diesel but of course that's your decision, but I hope you ordered 4.30 gears for that gasser. As far as the hitch and again for that big of a rig I wouldn't have anything but an airbag type hitch. I did a lot of research on 5th wheel hitches and decided on a Hensley TS3 air bag hitch for ours.
Luckily I found a like new 4 yr. old unit and I couldn't believe how nice our 5th wheel rode, no bouncing or chucking. These TS3's aren't cheap but if you can find a good used one you'll save some money. Unfortunately there are 2 cons....you'll need their adapter to mount the hitch to the Ford factory underbed puck system and they are HEAVY, you'll need an engine hoist or the like to get it in and out of the bed, about 315 lbs. Good luck with whichever you choose
Old Jan 21, 2017 | 09:55 AM
Good listener's Avatar
Good listener
Our Ford/Reese 18k does not make any noticeable noise pulling our 10k trailer. You may have been too close to the capacity of the hitch.
Old Jan 21, 2017 | 11:07 AM
djousma's Avatar
djousma
Thanks
Dan,
I've been running the Demco 21K Hijacker autoslide since about this time last year when I bought the Cardinal in my signature. It was my first 5th, and I wasnt sure if I needed a slider or not, but am glad I went withe Demco autoslide. I just dont have to worry now, and I've been in some pretty tight sites. I like the jaws in that they wrap around, and then also have a slide bar that closes after that. So there is no question on whether its fully locked or not. If there is a downside, its the sheer weight of the hitch. I had to install a chain hoist from harbor freight in my garage to be able to lift it in/out of my truck for the winter season when I put my tonneau cover on.
I'm very happy with the hitch, both etrailer, and dyers rv had great online prices.
I see you are in MIchigan. I'm on the west side.
EDIT: I see you have the longbed, and didnt realize they made a non-slide hijacker as well. Looks to be the same head though, so my comments should still help.
Good luck!
Old Jan 21, 2017 | 12:08 PM
workingdan's Avatar
workingdan
Originally Posted by djousma
Dan,
Good luck!
Yes the locking arm and wrap around lock is what sold me on it. Yes weight is a concern, i have a chain fall in my garage to get it in and out, so shouldn't be a problem.
I wont be towing as often now, i put my camper on a seasonal site in Hopkins.
Thanks for the feedback.
Old Jan 21, 2017 | 12:43 PM
djousma's Avatar
djousma
Sandy Pines? I am in GR. if thats where you go, we used to have friends with a place out there, and would visit a lot. Like it a lot, but we enjoy moving around.
Old Jan 21, 2017 | 01:05 PM
workingdan's Avatar
workingdan
Hidden ridge. We moved around alot last year and it was to much work. So we are going to try this for a season and see how it works out.
kdubinwa
6.7L Power Stroke Diesel
18
Sep 9, 2020 09:47 PM
fortheford
All Things Towing
18
Jul 16, 2019 12:32 PM
Greengas
Oct 28, 2017 03:48 AM
Budlight592
Dec 9, 2012 10:34 AM
JJPMach1
All Things Towing
Apr 13, 2007 06:55 PM
