2007 E-250 Electrical issues
Old Jan 18, 2017 | 03:13 PM
govango's Avatar
govango
I lost dome lights, radio, power windows and gauges needles. Other than that the van runs fine.
In the Passenger Compartment Fuse Box, fuses 3, 4, 11, 27, 30, 33 and 39 aren't getting any voltage across them when I check with a multimeter but the fuses look fine.
Everything in the Power Distribution Box under the hood tested fine including relays but when I took out the accessory delay relay and it worked the same way.
How do I figure out where the issue is and what needs to be fixed? It stems from replacing the OEM radio, I suspect something shorted out somehow.
Old Jan 19, 2017 | 12:49 PM
Wildman25's Avatar
Wildman25
If you replace the radio, back-track from there, remove the new radio and see what the results are, you could have very well crossed wired something at that point.
Did you use an adapter kit for the after market radio, or just spliced into the OEM radio harness??
Other wise, you said the van runs fine, it starts with out a problem??
Reason I ask, when the alternator died in my '05, I lost all the dash gauges and dome light (no power windows here) and just made it back to my shop before it totally died running off just the battery. And yes, '05-'08 are the same wiring systems.
zss42002
13
Oct 25, 2019 07:44 PM
Somertimes
Aug 4, 2019 09:44 AM
JZZJ2V
Dec 11, 2018 12:53 PM
cmckale
Dec 10, 2016 08:07 PM
TexasRebel
Feb 19, 2009 11:45 AM
