Correct PCV valve ?
Old Jan 17, 2017 | 06:53 PM
jakeharp's Avatar
jakeharp
Smile Correct PCV valve ?
The stock PCV valve is smaller than the one currently on my valve cover. Is there a guide or size matrix for these ?
Truck was born a 76' 360 and is now a 76' 390 with the Cobra Lemans valve covers......... I want to replace the old PCV ... I can measure it out, but when I search for PCV's there isn't any measurement's given ...
Thanks
Old Jan 17, 2017 | 07:06 PM
Justin73supercamper's Avatar
Justin73supercamper
I have a 390 with the same valve covers. I wanted my pcv valve to have a 90 degree bend so it wasn't sticking straight up. I went to O'Reilly auto with my grommet and went thru the bins till I found the one I wanted. I know i wasn't much help but hopefully some. If you want I can measure mine and post it
Old Jan 18, 2017 | 10:21 AM
jakeharp's Avatar
jakeharp
Thanks
Thanks for the info and the offer, I think I will do the same this weekend and rummage the local Auto stores for a matching PCV . I also have the 90 degree elbow to deal with........
Old Jan 18, 2017 | 01:45 PM
resonateur's Avatar
resonateur
If you have a Pep Boys near you, they have them on the self-serve shelf, so you can just go through them and open the boxes. Usually its a "low" part number, since you're looking for an earlier application you'll find it on the top shelf.
Old Jan 18, 2017 | 02:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Two different smog valves are listed for 1973/76 F100/350 360/390:
Scroll down to 6A666 in parts catalog pic.
Note: D9OZ-6A666-A replaced D8AZ-6A666-A & (not shown) D3OZ-6A666-A
Note: T/E = Thermactor Emission-smog pump.
Old Jan 18, 2017 | 04:14 PM
jakeharp's Avatar
jakeharp
Thanks
Thanks fellas, will see what I can come up with.....Thanks ND
Homerunking2394
6.2L V8
Nov 28, 2017 09:27 AM
LARIAT 85
Sep 28, 2007 05:34 PM
b4000 owner
1983 - 2012 Ranger & B-Series
Mar 6, 2005 08:54 PM
kevins70
Mar 30, 2002 09:00 PM
