Got the Gatorbacks Installed!
Old Jan 13, 2017 | 03:11 PM
powellbj's Avatar
powellbj
The shop that detailed the truck offered to install them for $125. Little did they know what they were committing to, took them ~5 hours to get all the brackets and flaps installed. They called me half way through and told me they underquoted me. Told them too bad and they honored the quote. F350 in front, Powerstroke in back. I do need to adjust the rear brackets they have them hanging woefully outside the truck.
Old Jan 13, 2017 | 03:27 PM
HouseMouse's Avatar
HouseMouse
Got mine installed today also and by the local Dealer here. They are awesome.
Old Jan 13, 2017 | 04:35 PM
grampscamper's Avatar
grampscamper
They look great!!!
Old Jan 13, 2017 | 04:36 PM
jlalanas's Avatar
jlalanas
They look good. Mine arrive sometime next week, so that will likely be my sat morning project....I've watched the youtube video a couple time, so hopefully it doesn't take 5hours....
Old Jan 13, 2017 | 04:43 PM
biz4two's Avatar
biz4two
Arrow
Nice setup! I like how you differ the front and back. Cool combo!
Yah, I've been watching those u-tube vids as well. Definitely not the easiest mudflap to install, but look HIGH quality all the way.
biz
Old Jan 13, 2017 | 05:21 PM
JasonB1's Avatar
JasonB1
It took me about 5 hours also.
They look good but they should have the same tolerance to the fender front and back. Also, on the rear, the top part of the inner fender support (the aluminum piece) should be in a bit more.
ETA: Sorry, I see you noticed the rear bracket already.
Old Jan 13, 2017 | 05:29 PM
JasonB1's Avatar
JasonB1
It takes bit of time.
IMO, on the front, go ahead and start the bottom screws (the stock ones you took out earlier) a bit, then line up the inner bracket. Also, when attaching the bracket to the stock studs underneath, be particular you don't strip the nuts out. They have some fine threads.
On the rear, the nut you are trying to remove that is hidden underneath the OEM liners (if you have them) is a 10MM. You need a 10MM ratchet wrench to get to that booger. Again, only if you have the OEM fender liners.
Also, your if your truck has flares, you will use those longer cap screws and nuts that come with the kit.
Old Jan 13, 2017 | 07:20 PM
jlalanas's Avatar
jlalanas
Thanks for the heads up. I ordered for the front and rear, but I'm only going to install the rears, waiting on the no drill bracket for the front of the 450, hopefully they are working on those an will be available in the near future. For not Ill leave the stock ones on the front.
I actually installed the liners after I took delivery so I had a good view of where that bolt is you're referring too.
Old Jan 13, 2017 | 07:40 PM
JasonB1's Avatar
JasonB1
Good deal. You'll drill a hole in the liner and use that stock mounting hole for the bracket.
One last tip:
When you're scooting around on your wheeled mechanic's stool from the driver's side to the passenger side, don't get in such a hurry that you skin your knee on the exhaust tip.
That sucker is sharp!
Old Jan 13, 2017 | 09:01 PM
nullop's Avatar
nullop
I bought mine a few weeks back and they've been sitting in the garage. It's just the flaps, 10 screws and 10 washers.
Is there a bracket I should go order as well?
Old Jan 13, 2017 | 10:24 PM
JasonB1's Avatar
JasonB1
It should come with all the brackets if you ordered the Gatorback kit.
Old Jan 13, 2017 | 10:34 PM
nullop's Avatar
nullop
Looks like I didn't (and not clear why it says they are "minis", i just selected my model/year and length.
Gatorback Gunmetal Mini Mud Flaps
Part#: TRH-GM1018CUT
Size: 10 x 18" (notched)
Logo: No Logo
Finish: Gunmetal w/ Stainless Hardware
Vehicle: F350 Ford 2017 2
OGTerror
General Automotive Discussion
Jul 25, 2011 05:37 PM
ccarrier
Aug 19, 2010 05:21 PM
SCRWDRVR
Delaware Chapter
33
Sep 8, 2009 04:40 AM
akford351
Feb 24, 2009 03:24 PM
