MacNeil WeatherTech Mud Guards Installed
Old Jan 11, 2017 | 03:10 PM
bigbrownf250's Avatar
bigbrownf250
Put my new WeatherTech Mud Guards on today. Easiest and most straight forward install ever. High quality fasteners were supplied as well.
Left Rear
Left Front Interior
Left Front Exterior
Old Jan 11, 2017 | 03:34 PM
user 474747383's Avatar
user 474747383
I have them also, I've always used Husky but I like the upper mounts on these better, No double sided tape.. much better.
Old Jan 11, 2017 | 03:56 PM
bigbrownf250
Definitely. These things are on there. They're not coming off.
Old Jan 11, 2017 | 05:51 PM
cayenne's Avatar
cayenne
I just wish they would hurry up and come out with the model for the trucks with wheel moldings like the KR edition. Can't wait to get my hands on some
Old Jan 11, 2017 | 09:18 PM
TruckGuy@SharpTruck.com's Avatar
Former Vendor
That's a nice looking truck!!
Old Jan 11, 2017 | 09:59 PM
klassic's Avatar
klassic
Glad you're happy with them. I've been waiting two weeks for Weathertech to call me and tell me mine are in.
I have been thinking about the back steel locking bar squeezing against the aluminum and road salt being a catalyst to some aluminum corrosion.
Any thoughts?
Old Jan 12, 2017 | 06:12 AM
user 474747383
I used a piece of their scrap clear wrap on the inside edges I got from the tint shop they use for rapping bumpers/hoods/paint.
Old Jan 12, 2017 | 06:15 AM
SparkyAl's Avatar
SparkyAl
I'm convinced, I'll order a set for mine today.
Old Jan 12, 2017 | 08:10 AM
snelldawg's Avatar
snelldawg
I installed them as well and like them. I didn't want to deal with double-sided tape, doesn't seem like a good option, especially during winter with snow slush build up on them.
Old Jan 12, 2017 | 08:20 AM
bigbrownf250
I'm gonna use "Fluid Film" and soak the inner fender well lip with it. This should apply a protective barrier.
The metal turn tab on top is coated with rubber. It's not bare metal. They don't advertise it, but it's coated rubber
Old Jan 12, 2017 | 12:06 PM
ecsb82's Avatar
ecsb82
Any thoughts?
I installed mine yesterday too. My lock bars had a rubber covering over it so there would not be contact of metal to aluminum. Also came with aluminum washers for the rear mud flaps because they get bolted through existing holes.
I also ran a bead of clear silicone inside the mud flap before pressing it to the truck. I did the same on my 2011 and never had a problem so figured it couldn't hurt.
Old Jan 12, 2017 | 01:54 PM
klassic's Avatar
klassic
I wasn't aware of the rubber over the steel tab. That's great.
I really need some flaps. The power running boards are getting sand blasted from the winter road spray.
Old Jan 12, 2017 | 03:15 PM
bowser4x4's Avatar
bowser4x4
Mine are to be delivered this tomorrow: I also have some of the 3M Clear Film that I am going to use under the part that comes in contact with the paint.
One question: The guard comes pretty close to the exhaust: any problem with the heat during a Regen on the 6.7?
Bowser
Old Jan 13, 2017 | 03:19 PM
bigbrownf250
for the rear, I put the washer on the phillips screw side on the tire side. Tried to just use the screw and put the washer on the back, but the screw was sloppy through the hole on the actual flap.
Old Jan 19, 2017 | 12:07 PM
dannko's Avatar
dannko
so from a side view have they added a "curve" to it like the Husky's? Instead of a straight down profile.
