Converting 2wd to 4x4
Old Dec 19, 2001 | 11:26 PM
EaSTxCOwboY's Avatar
EaSTxCOwboY
I have a 94 F-150 ext cab with a 5.0 and 5 speed. Im thinking about converting from 2wd to 4x4. I want to put a 3 in body and 5 suspension. Anyone care to comment on what i should do? open to any suggestions.
Thankz
Kyle:-X12
Old Dec 19, 2001 | 11:55 PM
PAUL_2's Avatar
PAUL_2
Its much easier & a lot cheaper to go buy a 4x4 & do whatever you want to it . What you want to do is $$$$$ & a lot of work .
Old Dec 20, 2001 | 11:02 AM
EaSTxCOwboY
conversion of my 2wd to 4x4 is going to be done by Arlington 4 wheel drive. Im buying the axels from them and trasfer case and they will install it. Then im going to ##### Cecpeck place in Denton and having the tires,rims,and lift put on. So there for im only spending between 3-4,000. At least thats what i think. Anyone care to comment
Old Dec 20, 2001 | 04:01 PM
DoubleA's Avatar
DoubleA
Not crazy if you like your truck that much. I did this to my 94, 2x4 to 4x4, 4" suspension, 3" body, changed I6 to 302, 3/4 ton rears and would do it again.
I came across the parts pretty cheap, did the work all myself and not including the engine swap and rears, only had about $2000 total. $500 was just to change the 2x tranny to accept the xfer case. much cheaper than a junk yard tranny that was in a wreck and who knows how long it will last.
the cost difference of what you'd have between selling yours, buying a new 4x4, not knowing what you're buying.....
pretty much equals out in dollars.
Old Dec 20, 2001 | 04:08 PM
75highboy's Avatar
75highboy
Post Converting 2wd to 4x4
