Clogged oil pump
Old Aug 27, 2003 | 10:13 AM
rglarguy's Avatar
rglarguy
Clogged oil pump
I posted this on the Explorer forum, but I am hoping to get some ideas before I reassmble my 92 4.0.
My oil pump was clogged with some debris and the oil has fine metal in it. The bearings don't look bad enough to have produced that much metal, and the oil pump is not damaged too badly. The pump has been clogged for only 100 miles. Where else could the metal come from?
The engine runs great is strong and sounds fine except at 3000 or so RPMs it was clattering like a deisel. I origianlly thought this was a couple of loose rod bearings, but it may have something to do with the clogged oil pump. I will appreciate any input.
Old Aug 28, 2003 | 08:56 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Clogged oil pump
It'll be extra work, but I'd take a look at the timing chain and gears. Maybe the chain is rubbing against something. That would explain the clattering at higher rpms......
