Ok.... 66' short bed that originally had a 240 with a 3 on tree. This engine was pulled and I purchased a running 352 with automatic transmission. Is there a difference in the interior hump height and transmission cross brace under? Will the original drive shaft work? I know this a lot of questions! Thanks in advance!
Number Dummy....you rock! I knew I could count on this site for answers! Luckily I will have access to the driveshaft from the donor if needed. What do you think on the hump clearance? Any difference?
I don't think it matters for clearance, but my cruise-o equipped truck doesn't have a removable transmission cover plate. Just a very small cover plate on the passengers side to access the band adjustment on the transmission. I believe this was same 1965/66.
