1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Oil Life Meter Reset In a 2016
Old 01-05-2017, 10:05 AM
Rob89's Avatar
Rob89
Rob89 is offline
I'm having trouble resetting my oil life meter in my 16 F250. I think I'm doing exactly what the manual says but nothing is happening. I turn the ignition on and wait a second for the ford start up graphics to finish and then press the gas and brake at the same time as far as they will go. The manual says after 3 seconds I'll see a message saying the reset is in progress but I don't get any message on the screen. Am I doing something wrong?
Old 01-05-2017, 10:52 AM
SnowPlowDriver's Avatar
SnowPlowDriver
SnowPlowDriver is offline
that method wouldn't work on my 2016 xl either.on mine I hit setup twice then reset. If you have an info screen try going to maintenance.
Old 01-05-2017, 10:58 AM
Rob89's Avatar
Rob89
Rob89 is offline
I went to maintenance and the only option is for the coolant. There is no option for oil.
Old 01-05-2017, 12:43 PM
seville009's Avatar
seville009
seville009 is offline
On my 2011 F350 6.2l, the oil reset is via the screen behind the steering wheel - scroll thru it using the left side menu buttons
Old 01-05-2017, 02:40 PM
Wingit929's Avatar
Wingit929
Wingit929 is offline
this is where mine is at
Old 01-05-2017, 03:13 PM
Rob89's Avatar
Rob89
Rob89 is offline
Originally Posted by Wingit929
https://youtu.be/EkudxPR4yEU
Thanks. That's where I found mine at. The owners manual was way off base about this one!
clintbonnie
Escape & Escape Hybrid
05-17-2019 10:28 PM
Brdhunter
2017+ Super Duty
05-19-2018 11:52 AM
egregg57
6.7L Power Stroke Diesel
08-15-2016 02:36 PM
Tacswa3
02-21-2016 04:29 PM
burrhead
6.2L V8
07-09-2011 12:12 AM
Quick Reply: Oil Life Meter Reset In a 2016
