Sponsored by: Real Truck
Help finding a fuel tank
Old Jan 3, 2017 | 12:39 PM
mepatterson74's Avatar
mepatterson74
Dealership found a crack in my fuel tank. The tank that I need they no longer make. The dealership had my truck for ten days trying to find one but no luck. I've been looking everywhere. It's a 2002 Ford F250 Super Duty V10 Crew cab. Part number is F81z9002TA. Midship fuel tank, 156 wheel base, plastic tank with low emissions. Any help would be greatly appreciated. Thank you.
Old Jan 3, 2017 | 01:18 PM
Chuck's First Ford's Avatar
Chuck's First Ford
Wrecking Yard, Junk Yard.. Towing yard., E-bay. used, but so is your truck.
Old Jan 3, 2017 | 01:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Part number is F81Z-9002-TA .. Midship fuel tank, 156 wheel base, plastic tank with low emissions. Any help would be greatly appreciated. Thank you.
F81Z-9002-TA .. Fuel Tank / Obsolete
Last MSRP: $1,686.47 - Dealer net cost: $1,011.88.
No Ford dealer or obsolete parts vendor has any.
An aftermarket fuel tank liner may be your only solution. Available from auto parts stores, radiator shops.
Radiator shops usually are the ones that can "boil out" fuel tanks.
Old Jan 3, 2017 | 08:30 PM
dwigmore's Avatar
dwigmore
Check out Titan tanks, or at least see if there's a local dealer. I put a Titan tank on my diesel and couldn't even give the old tank away. A dealer might know of someone with a stock tank to get rid of....
Old Jan 3, 2017 | 10:37 PM
Sam I Am's Avatar
Sam I Am
Parts Geek
Rock Auto
both show to have some tanks in stock for my 99 SD. If you have to have new you may be looking at adapting a different size tank to fit your truck or using one from a different year model.
May be a good time to upgrade to a bigger tank.
Gadget185
Aug 16, 2020 08:09 PM
beersy50
Oct 11, 2014 10:17 AM
69_bronco
Nov 2, 2011 10:12 PM
73strokin
Nov 8, 2010 05:40 PM
mrlightrail
Jul 9, 2008 02:42 AM
