Updating brakes
Old Jan 8, 2017 | 10:10 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Originally Posted by ultraranger
My 3/16" tubing bender (the black set) is made by Ridgid. The silver 3/8", 5/16" and 1/4" benders are made by Imperial.
Is this approximately equivalent to your Ridgid set?
https://www.amazon.com/Ridgid-36117-...2F16%22+bender
Old Jan 8, 2017 | 10:28 PM
ultraranger's Avatar
ultraranger
I bought my 3/16" Ridgid tubing bender back in the '90s. This seems to be more the version I have, although about $20 dollars more than what it was at the time I bought mine more than 20 years ago.
Ridgid 36117 3/16" Combination Tube Bender (403)
Old Jan 9, 2017 | 01:19 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Thanks.
Those seem to both be Ridgid 36117 benders. I wonder if there is really a difference between the 36117 on Amazon versus this one? Or something different even though they seem to use the same numbering? One would hope not.
Chad
Old Jan 9, 2017 | 04:43 PM
ultraranger
The one in your link looks a little different to me as far as the handles and the grips goes, compared to what I have and in the link I posted.
Whatever difference, if actually any, I'm sure either would be a good set to have. My benders have over 20 years use on them and they still make nice very bends.
Old Jan 15, 2017 | 02:20 AM
tbm3fan's Avatar
tbm3fan
I surely won't be doing my brake lines like this guy did on a 68 F250.
Old Jan 15, 2017 | 03:51 PM
yankbs 66f100's Avatar
yankbs 66f100
Hopefully that was his first attempt, not the final one Mike.
Old Jan 15, 2017 | 07:48 PM
ultraranger
You can always tell the difference between a line that was hand bent, vs ones that were bent with a tubing bender.
Old Jan 15, 2017 | 09:05 PM
tbm3fan's Avatar
tbm3fan
It is for sale on Craigslist and says that it has no brakes so it needs a tow.
Old Jan 16, 2017 | 06:11 AM
yankbs 66f100
That's funny Mike, sad but funny.
Old Jan 16, 2017 | 07:18 PM
66v8baby's Avatar
66v8baby
Originally Posted by JefflovesF250s
I have a '66F250 that I've upgraded to a dual master cylinder, but kept the drum brakes all around.
I am using a Wagner dual chamber MC for a '67F250, and purchased a distribution block off eBay for a 67 Galaxie(entrance fittings for each line from MC, 2 exit fittings for front, 1 for rears). Had to custom make a bracket to mount it.
Bought pre-bent 3/16 inch SS brake lines from InLine Tube for a '67F250 and they all mounted perfectly on the '66 frame and connected perfectly to the distribution block and the fittings at each drum and rear axle housing.
The only mod I needed was to reverse the fittings on the two lines from the MC to the distribution block to fit the entrance fittings. I had InLine do that for me.(mods not expensive, but USPS wasn't cheap) They did a great job and added protection coiling to exposed legs from bracket at PS box to distribution block.
I'll mount a Tee with an 1/8NPT at the exit to the rear chamber to mount the line-pressure activated brake light switch.
Overall, keeps the set-up fairly close to original but increases safety with dual MC.
I'm also in the power drum camp with a dual MC. I went with a 68 F100 distribution block so I could use pre-fabbed lines to save time. However, another possible solution would be to use the original single feed MC block to feed the front drums and fab a line from the block (at the rear line) up to the booster area with a 3/16 inverted flare to 1/8 female NPT brass fitting for the original brake switch. If I wasn't in a hurry to get my truck back on the road I probably would have done that myself.
Old Jan 22, 2017 | 01:58 AM
Raptor10's Avatar
Raptor10
Originally Posted by alwill923
I have a 65 that I added a power brake booster with a double MC from MP brakes. The original MC was the single line MC with one tube down to a tee under the steering box. I did like you kept the drums all around. MP brakes sent me a MC designed for drums all around and thus did not require a proportioning valve. I disconnected the brake line to the front wheels from the tee and installed a plug. I then ran two lines down from the MC one when to the tee to the back wheels and the other line went to the line to the front wheels with a coupling. Works great. The only problem (there always is a problem with after market parts) was the bracket did not fit and I had to cut it and weld it back together in a different configuration.
MP brakes was very good about it and offered to refund my money but I wanted the power brakes so I fixed it.
When you run new brake lines use the new tubing that is flexible and easy to flare. I also put a tee in the line and used the original brake switch for the brake lights.
I'm having to do the same brake work to my 63 F350 dually. Do you have any pictures of your set-up?
thanks
Dan
Old Jan 22, 2017 | 10:16 AM
6t6merc's Avatar
6t6merc
The first time I did this I added a '67 dual mc and ran one line to a front splitter and one to the the rear axle, adding a Wilwood prop valve in the rear line at the mc. I had no other components in the system and it worked fine.
Eric
Old Jan 22, 2017 | 02:45 PM
  #28
tbm3fan's Avatar
tbm3fan
One question to double check my memory since I can't recall where I read it. When measuring your length of line from point A to B how much extra needs to be added to account for the flare and not be short? I recall the amount of 1/4" for each flare.
Old Jan 22, 2017 | 04:39 PM
  #29
ultraranger
This is a '65 F100 belonging to a friend of mine that I added a tandem MC to and did the brake line plumbing, after front disc brakes were added from a '78 F150.
I put a Tee in the line to install the pressure activated brake light switch into.
Old Jan 22, 2017 | 07:10 PM
  #30
6t6merc's Avatar
6t6merc
Very clean job, Steve.
