99 expedition trans. issue
Old Jan 1, 2017 | 08:54 PM
25twin's Avatar
25twin
Thanks in advance for any help.
expedition was working fine, drops rear u-joint due to rusted out parts. Now trans. just loads up and will not move in drive. Low and reverse works. It moves and shifts fine in drive if you turn the overdrive off.Any ideas what got damaged by the drive shaft flopping around?
Old Jan 1, 2017 | 11:03 PM
Casper99's Avatar
Casper99
not sure if this is similar to what your truck is doing but here's a link and there is a comment not sure if that whats wrong or not, something about a "solenoid pack"
Old Jan 2, 2017 | 08:22 AM
alloro's Avatar
alloro
Please elaborate more. Did the u-joint drop while driving, backing up, or do you mean you took it out and changed all of them?
Old Jan 2, 2017 | 11:00 AM
25twin's Avatar
25twin
clarification
The vehicle was driving when it happened. I'm sure when the u-joint let go the driveshaft banged around pretty hard. I'm pretty sure that is what caused the problem. It showed up immediately after the driveshaft was repaired and we started to drive it again.
Old Jan 2, 2017 | 11:28 AM
alloro's Avatar
alloro
If they changed the front u-joints at the double cardan joint as well then it's likely one of them was put in backwards.
Pastor Jared Parmley
Jun 8, 2019 09:21 AM
rodolan
Apr 23, 2009 07:56 PM
nininchnail
Apr 21, 2006 09:22 PM
156-vette
Sep 2, 2005 03:53 PM
hightower45
Feb 11, 2002 07:29 PM
