2004 exploder
Old Jan 1, 2017 | 04:57 PM
lgfuller's Avatar
lgfuller
2004 exploder
ok, I usually hang around in the older classic portions. but I'm currently working on a swap with a 2004 explorer 4.6 v8 eddie bauer. my pops and brother spun the center main bearing on the aluminium 4.6 that was original. the replacement they got, on my recommendation, was a 5.4, out of a 99 expedition. Ive seen and read many times that this is a bolt in swap. so far we find that the starter don't fit, and the depth of the flex plate is different. we have adapters to fit the stock 4.6 intake to the 5.4 so we can use the electronic throttle from the OE. wheat further advise is there to make this swap work? the OE 4.6 seems to be a romeo engine, and the 5.4 seems to be a Windsor....
Old Jan 2, 2017 | 01:38 PM
shorod's Avatar
shorod
I've never heard of anyone swapping a 5.4L in for the 4.6L in an Explorer. What model have you seen and read about this being done many times?
If you continue to tackle this project, make sure you change out those spark plugs in the 5.4L before installing it in the Explorer.
-Rod
Old Jan 2, 2017 | 08:51 PM
lgfuller's Avatar
lgfuller
ive seen the 4.6 to 5.4 swap done on f-150 and on the mustangs quite a bit. when the 4.6 went **** up in the exploder, the 5.4 was the best deal on a replacement motor... free99.... and the plugs are swapped, also installed a new oil pump, and a windage tray in the oil pan to help control oil flow. rather than throw the whole bit away, it seems to be coming together nicely though. Good to know I'm in uncharted waters these days. When we get it all done up, ill make sure and do up a build thread. document it as the first one to do so...........
Old Jan 3, 2017 | 06:49 AM
shorod's Avatar
shorod
Since the 5.4L was an option in the F-150 and, if I'm not mistaken, in the Mustang as well for the Cobra or Cobra R or something, I guess I'm not surprised it fit in those. But I do think you would be able to take credit as the first one to pull it off in the Explorer. A build thread would be great.
-Rod
Old Jan 3, 2017 | 05:08 PM
lgfuller's Avatar
lgfuller
it is duly noted that I will be the first to document the 5.4 explorer!!!!!!! just kind of what I had figured on that, after the deer in the headlights look from everyone else. we don't really expect to see horsepower improvements, but the greater displacement should see more torque, and since its all mass airflow, should be able to reuse the stock tune on the computer.
lgfuller's Avatar
lgfuller
btw, thanks Rod.
Old Jun 21, 2017 | 02:19 PM
lgfuller's Avatar
lgfuller
So, just an update on this, it took us longer than we planned, started the build on the day after Christmas, and finally got it fully functioning about a month ago. The pics are forth coming, I just have to finish compiling them from what I have, what my brother has, and what my dad has. End result is it runs fantastic. Way more torque than the original 4.6, it hardly even has to try when climbing a hill. The only major problem we had was making the exhaust work with the wider 5.4 and keeping the original 4.6 cats. In the haste of connecting the exhaust, the passenger side cat got smacked with a hammer out of frustration, and the ensuing rattle made us think that the torque converter was loose. Trans came out to make sure that TC and flywheel were tight. Then my lil brother bought a 04 CV that made the same rattle. That's when we figured out that it was the Cat. New walker cats and 02 sensors, rattle gone, runs like a dream.
Old Jun 23, 2017 | 07:34 PM
Misky6.0's Avatar
Misky6.0
Is the trans up to the task of the added torque? The trans in explorers can be problematic (especially the 2004, which only lasted us 54k miles).
Old Jun 27, 2017 | 03:06 PM
lgfuller's Avatar
lgfuller
So far no issues with the trans, and it has over 150k on it. It relearned my pops driving style, and he's happier than a pig in slop. Though, he does seem to tow way over weight with it, and it tends to wipe the rear wheel bearings...
Robert Bain
2004 - 2008 F150
Aug 2, 2019 10:34 PM
RedSTX04
Modular V8 (4.6L, 5.4L)
Aug 18, 2017 11:29 AM
ToolTime
1997 - 2003 F150
Oct 6, 2012 03:29 PM
justford
Engine Swaps
Dec 4, 2005 02:47 PM
zubes
Engine Swaps
Aug 29, 2004 08:52 PM
