Intermittent vibration
Old Jan 1, 2017 | 04:33 PM
Josh96f150's Avatar
Josh96f150
My truck is a 96 f150 I have a vibration that comes and goes as I am driving 40 mph and up goes from rattle your teeth out to perfectly fine just did a clutch I have checked and rechecked all bolts and drive shaft any help would be much appreciated.
Old Jan 1, 2017 | 05:11 PM
88n94's Avatar
88n94
Did you replace the pilot bearing, or atleast check the old one, when you did the clutch? I'm not sure if this would cause your problem though, just a thought.
Old Jan 1, 2017 | 05:16 PM
Josh96f150's Avatar
Josh96f150
Yes I did replace it and the truck only has 70000 original on it.
Old Jan 1, 2017 | 05:24 PM
Ddaybc's Avatar
Ddaybc
Intermittent vibrations can also be U-joints. Given that you just replaced your clutch it could also be clutch related. You may have to take is all apart again to see if there are any issues with the new parts.
dfritz
Jan 18, 2020 07:33 PM
Wbruiser2
1997 - 2003 F150
Jan 18, 2019 06:22 PM
corbin9191
Nov 2, 2011 07:43 PM
ReFlectiveMan
Sep 1, 2010 07:23 PM
donald mc
24
Nov 13, 2007 10:06 AM
