302 egine problem
Old Aug 26, 2003 | 06:59 PM
floorguy's Avatar
floorguy
302 egine problem
i have a 302 i have just rebuild it got 1300 mi on it. it has a low end cam. holley intake 650 holley carb. new heads everything is new. i been have to much presure in the engine for some reason. it blows out my intake gasket and valve cover gasket. i dont know if it is my timing is off because of the new cam. any thing will help please.
82 ford bronco
Old Aug 26, 2003 | 07:57 PM
Jimbo302's Avatar
Jimbo302
302 egine problem
Are you saying it has alot of crankcase pressure? Blowby? If so, the rings are bad.
Old Aug 26, 2003 | 09:18 PM
natewoz's Avatar
natewoz
302 egine problem
Is your crankcase breather obstructed? If the engine cn't breathe, you would get lots of pressure inside.
Old Aug 26, 2003 | 11:39 PM
DW2455's Avatar
DW2455
302 egine problem
do a compresion check on all eight cylinders, you not looking so much for how much pressure but uniformity, make shure there all pretty close together, and go from there. Good luck! DW
