1978 - 1996 Big Bronco
351w compound problem
Old Aug 26, 2003 | 06:55 PM
godzirra's Avatar
godzirra
Unhappy 351w compound problem
HELP!!!! If anyone could help me with this issue,I would be eternally grateful. 86' bronco 351w HO. the suspension, 4wd, and tranny are almost in new condition, but Im having motor problems. doesnt burn oil, runs great (for a while, maybe 20 minutes) then oil pressure drops with the rpm's, and at the same time the motor gets good and hot. When I shut it off it spouts water everywhere. replaced the oil pump and the sump. still looses oil pressure after it warms up good, and still gets too hot and boild over when I stop the motor. oh, and water flows fine through the cooling system.
Old Aug 26, 2003 | 11:07 PM
DW2455's Avatar
DW2455
how many miles have you pressure tested the cooling system to see if you have a leak like a blown head gasket,cracked head, block.? does it skip, shake, run rough? do you have any water in the oil, is the oil milky looking? you could have a strethched timing chain? DW
Old Aug 26, 2003 | 11:22 PM
justshootme84's Avatar
justshootme84
I would be more concerned with the over-heating problem than the oil pressure. Don't put alot of faith in the factory oil press. gauge and sending unit. A lower-temp thermostat may help, but only if the radiator and rest of the cooling system are working. Might be as simple as replacing the radiator cap, or might need a complete system flush.
Old Aug 27, 2003 | 10:20 AM
Kemicalburns's Avatar
Kemicalburns
I would get the radiator flushed and rodded, also check your thermostate, maybe it got put in backwards and is cause flow issues as well. I would do the pressure test as well to see if a gasket has gone.
good luck
Old Aug 27, 2003 | 03:27 PM
jeep8589's Avatar
jeep8589
Oil pressure problem sounds like the bearings are worn. When the oils is cold it holds pressure better and is harder to flow around the bearings. As it heats up it thins and you loose oil pressure. This happens normally even when the bearings are in excellent shape but the drop is more severe as they wear. I had a 350 that did exactly the same thing. As for the overheating, If this started happening all of a sudden and was not an ever increasing problem I would look for a blown head gasket or cracked head/block. When the engine heats up the metals expand and you could be blowing exhaust into the coolant system causing the overheating problem. Your oil pressure problem may be because it is getting way too hot and not holding its viscosity. So, your bearings may still be OK. If the heating problem has slowly been developing, then I would check the cooling system for a blockage.
Old Aug 27, 2003 | 05:32 PM
justshootme84
That's areally good point about the worn main bearings.
Old Aug 27, 2003 | 06:09 PM
frogger01's Avatar
frogger01
When you say it spiurts water everywhere where exactly is it comming from? Also the hoses when it gets like this can you squeeze the upper hose at all? if you can then you have a stuck thermostat if you dont then it's possible one of your head gaskets have blown. As others have said take a look at the oil see if it's milky, also take a look at the coolant drain it if you have to. make sure there is no contamination of the oil in the water and no water in the oil. One other thing to do is to pull the spark plugs and take notice of any fouling or other evidence of head gasket failure.
smokenchoken
Sep 2, 2014 04:12 PM
gurgh2010
Sep 19, 2012 10:26 PM
RangerHaywood
Jul 13, 2010 04:01 PM
nanaimobarz
Sep 19, 2003 06:19 AM
bigpaul
Jun 26, 2003 10:39 PM
