Power port setting?
Old Aug 26, 2003 | 06:42 PM
D2EBMA's Avatar
D2EBMA
Power port setting?
I have a radar detector plugged in to the power port on my '00 EB Expy, but the port is always powered (forcing me to turn the radar on and off every time I want to use it). I will (if I have to) rewire it to be tied to the ignition, but wondered if there's a setting somewhere (a la turning the key 10 times or something) that I can use instead.
Any help is much appreciated.
Thanks.
D
2000 Eddie Bauer
5.4/K&N, 14MPG and I don't care
Old Aug 26, 2003 | 07:02 PM
HomerWinzlow's Avatar
HomerWinzlow
Power port setting?
No, no such luxury. You will have to wire it to the switched circuit and fuse it.
Old Aug 26, 2003 | 08:14 PM
daveplot's Avatar
daveplot
Power port setting?
It may be easier to go to Radio Shack and buy a female plug, then hide the plug under the dash and wire it to a switched fuse.
Old Aug 26, 2003 | 09:12 PM
Luzer27's Avatar
Luzer27
Power port setting?
Why not just leave it on. It pulls less than 500ma and it would take months of none use to discharge your battery and from an electronics standpoint it is better for the life of the unit to just leave it on. ???
-Dave
Old Aug 26, 2003 | 09:15 PM
Mattias's Avatar
Mattias
Power port setting?
I guess it depends on what radar detector you have but most higher end models come with both a cigarette lighter AND a hard-wire with inline fuse. If not bring your detector to Radio Shack and find a head plug that fits or you can butcher your oem cigarette head plug.
Just find the fuse for something which is ignition controlled like the power window fuse in the box and take it from there. It's such a low amperage draw that it's ok.
