Goopy injector mean anything?
Old Dec 28, 2016 | 11:35 PM
163junk's Avatar
163junk
Maybe the loose injector got the oil a little warm on that side. How do the copper washers look on them ?
Old Dec 28, 2016 | 11:44 PM
seijirou's Avatar
seijirou
The copper washers looked crushed and fine on that side, even on the one that didn't have any torque I didn't see any carbon trails across the washer. All the cups have cleaned up really easily too.
What I'm really happy about is all the spool valves look brand new. I pulled them out to do the "twoiceburgs" cleanup job on them but they're all perfectly clean and not scuffed at all. The coils don't have the notches though so I know they're not recent remans.
The only thing that seemed strange was the goop.
I definitely had upper seal issues. 2 of them were showing signs of breaking down, one was split.
Old Dec 28, 2016 | 11:46 PM
FiznUKa's Avatar
FiznUKa
I may be mistaken but there should not be oil in the cup. There is no hole for it to enter or exit.
Old Dec 28, 2016 | 11:52 PM
FiznUKa's Avatar
FiznUKa
Were the cups in the heads ever changed? If you had an oil cooler come apart and the injector cups were not done correctly you could have leaked the oil/coolant mess in the cup. Anything possible.
seijirou's Avatar
seijirou
Aw damnit, see that's what I thought too. Which means no-pressure oil got past 2 rings and high-pressure fuel??
Old Dec 28, 2016 | 11:54 PM
seijirou's Avatar
seijirou
I have no idea, not the original owner.
I thought you only replaced injector cups if one cracked, identified by fuel in the coolant? Would oil cooler problems lead to injector cups?? I don't see the correlation.
I think the oil cooler was done before I got it, just to do it. It was studded and egr deleted at the same time. The person that did it, I'm pretty damn sure did a rush job on it.
Old Dec 28, 2016 | 11:55 PM
163junk's Avatar
163junk
ooopsy brain fart on my side, no oil at bottom just fuel between the o-rings, had 7.3 on the brain.
Old Dec 29, 2016 | 12:00 AM
FiznUKa's Avatar
FiznUKa
If you had an oily coolant mess when the oil cooler let go it could have possibly leaked past the sealant for the injector cup. Also those orings on the injector don't look that old. Usually the white is worn off when you pull a stick.
Old Dec 29, 2016 | 12:09 AM
seijirou's Avatar
seijirou
It would have had to leak coolant too though? It's definitely not a milk-shaky.
Old Dec 29, 2016 | 01:51 AM
87crewdually's Avatar
87crewdually
Some sloppy mechanic coated those injectors with grease prior to assembly. There is no reason to. I've come across it before and again just recently. No worries.
Old Dec 29, 2016 | 06:17 AM
navistarnut's Avatar
navistarnut
Originally Posted by seijirou
Yeah no tiny vacuuming here, the injectors on that side are all back in now.
Did you do this job after noticing the truck making oil?
Old Dec 29, 2016 | 06:53 AM
WatsonR's Avatar
WatsonR
Beat me to it Pete...
goodtyms1432
34
Apr 16, 2021 08:50 AM
01 PSD
Nov 27, 2016 11:12 AM
triplerpos
Oct 1, 2014 10:52 PM
tjbeggs
48
Feb 11, 2009 11:03 AM
barebackjake
Nov 10, 2004 08:12 PM
