Transmission installation help
Old Dec 28, 2016 | 04:57 PM
BTFordGuy302's Avatar
BTFordGuy302
Hey guys, the clutch went out in my 96 f150 6cyl 5 speed and I just got all the parts installed. However, i can't get the transmission to butt up against the back of the engine. It looks like the end of the internal slave cylinder is hitting the diaphragm of the clutch pressure plate and not letting it go in any further. Has anyone else encountered this? If so how do i get it to go in the last 2 or 3 inches or so? Thanks guys
BTFordGuy302
Forgot to mention it is 2 wheel drive!
Old Dec 28, 2016 | 05:31 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Slave not seated all the way? That is a lot of space to make up.
Old Dec 28, 2016 | 05:35 PM
BTFordGuy302
Nah it's seated all the way, that's what I was thinking at first too, i lied though, it's like an inch inch and a half tops, it backed out a little when I was maneuvering it, I got it back to about an inch or so...
Old Dec 28, 2016 | 10:07 PM
88n94's Avatar
88n94
Did you use an alignment tool when you bolted the pressure plate to the flywheel so the clutch disc would be aligned(centered) with the pilot bearing?
Old Dec 28, 2016 | 10:53 PM
wtroger's Avatar
wtroger
Put the trans in gear and turn the output shaft if you are started in the clutch splines it won't turn. Turn it until it does drop in the splines. Then push it should start in. I have had them tight enough I had to thump the back of trans with a rubber mallet to get it forward enough to get the bolts started.
Old Dec 29, 2016 | 04:43 AM
BTFordGuy302
yessir, I was lucky enough that one came with the clutch kit I bought.
Old Dec 29, 2016 | 04:46 AM
BTFordGuy302
that's a thought. Any particular way to grab a hold of the outpoutput shaft to turm it? Probably have to use the driveshaft right?
Old Dec 29, 2016 | 06:09 AM
EPNCSU2006's Avatar
EPNCSU2006
Assuming the input shaft splines are aligned with the clutch disc and the disc aligned with the pilot bearing, open the bleeder on the slave cylinder. I had the same problem once. Cover the open bleeder with a rag, otherwise it will shoot brake fluid.
Old Dec 29, 2016 | 10:03 PM
BTFordGuy302
you sir, are a gentalmen and a scholar! That did the trick, looks like Betty will be back on the road tomorrow!
Tiggie
1983 - 2012 Ranger & B-Series
Sep 5, 2015 08:11 PM
countrymike48169
Feb 25, 2006 09:58 AM
hj84f150
Jan 31, 2004 04:21 PM
ffulkerth
Aug 11, 2003 09:46 AM
